LS 5030 3 POINT FULL UP POSITION
/ LS 5030 3 POINT FULL UP POSITION #1
Sweetcreek
SISTERSVILLE WV
LS5030C
OUR 5030 suddenly went to full up position and will not lower.
Speed valve is open , position & draft & quick lift are in lowest position .
also the hydraulic pump is under load .
If you remove the speed valve the oil squirts out the three point drops .
Desperately hoping not to remove the entire unit off the pumpkin , any ideas gentlemen ?
/ LS 5030 3 POINT FULL UP POSITION #2
Any chance one of your remotes is in detent?
Hopefully this will save somebody a lot of work/money .
As you face the tractor there is a relief valve on the left side of the hydraulic unit .it. Is about 4 inches back
From the front of the unit and down on the side about 2 inches
The speed valve for the 3 point drop goes straight into the front of the hydraulic unit
You most remove the seat or the left rear tire .
You disconnect the linkage for the 3 point position & draft height
It takes a 22mm socket to remove the valve it is about 1 3/4 long , new relief valve is about $60.00
If you know this its a 4 hr job , if not tear the entire unit of the pumpkin ,towmotor and 3 men &40 hrs
2016 Volvo VNL T/A Sleeper Cab Truck Tractor (A61573)
2016 Volvo VNL T/A...
Pat's QH and hydraulic top-link.
Pat's QH and...
2019 Nissan Sentra (A61574)
2019 Nissan Sentra...
SANY SY225C LC EXCAVATOR (A63276)
SANY SY225C LC...
Challenger MT275B 40HP 4WD Utility Tractor w/ 76in. Rotary Brush Cutter Attachment (A59228)
Challenger MT275B...
1999 TRANSCRAFT FLAT BED 48FT TRAILER (A59905)
1999 TRANSCRAFT...
