Mowing LS 5020C PTO Problems
/ LS 5020C PTO Problems #1
spectre533
troup
LS5020C
The PTO on my new 5020C would not work from day one. Dealer replaced some kind of hydraulic controller and it worked for 4 hours and same problem came back. When I turn on the PTO switch the indicator light on the dash panel lights up for 3 seconds, then goes out and the transmission pressure light comes on. The PTO never rotates. Anybody else had this problem?
/ LS 5020C PTO Problems #2
60hrs and no issues with U5030. Ask for a different unit.
HS
/ LS 5020C PTO Problems #3
Sounds like a transmission issue. Id have them crack the case at a minimum and take a look. What's your dealer saying?
/ LS 5020C PTO Problems #4
ditto to what has been said. Sounds like somebody fubared the assembly. Maybe put a one way valve on in the wrong direction...?
/ LS 5020C PTO Problems #5
No problem with my 7010 but I havent used the pto much. I think the new unit suggestion is the way to go. Why accept a tractor that had to go to the shop on day one. How much have you used it so far. If you used it for several hours prior to discovering the issue, then you may not be able to "insist" on a new unit, but if they had to immediately take it back, then BRING OUT ANOTHER ONE MISTER DEALER.
/ LS 5020C PTO Problems #6
Does lemon law apply to tractors? 3 strikes and your out. Good luck.
/ LS 5020C PTO Problems #7
OP would have to check their state's laws. It is different from state to state.
Thanks for the inputs. Lemon law in Texas is in effect and it is three strike and out. The 5020 is in the shop now for the 3rd fix and I'm betting they don't come up with a good fix. Will update the outcome.
/ LS 5020C PTO Problems #9
Glad to hear it. I'm hoping the dealer is being helpful. Kinda surprised LS USA hasn't made a post. I'm sure they are reading.
/ LS 5020C PTO Problems #10
Has LS USA ever post here or anywhere.
CASE 610 Sprayer System 2000 Gallons (A61307)
CASE 610 Sprayer...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2025 SDLanch SDLE20 Diesel Mini Excavator (A60352)
2025 SDLanch...
2020 Bobcat MT85 (A53317)
2020 Bobcat MT85...
John Deere 655 (A60462)
John Deere 655...
2009 CHEVROLET C8500 CREW CAB FLATBED TRUCK (A59823)
2009 CHEVROLET...
