Lower ROPS
   / Lower ROPS #11
When you're measuring how much you're going to cut off...sit in the seat...put the seat belt on and lift up hard with legs and arms and see where your head goes to. This will be the height your head is going to be when the tractor is upside down and you're hanging in the belt. Leave some more inches for compaction of the ground when the roll bar buries into the moist earth.
In other words...leave some extra inches above your head otherwise the reason for the bar being there isn't worth the modification.
A very good summary, had not considered the soft ground or mud..But always think about being in pond water? Too many people drown on tractors, for our own good...I guess I will keep pulling the top section off and putting it back on when out of garage?
   / Lower ROPS #12
That bar isn't just for rollovers. It's also for flips.
I have to agree with nebraskasparks, it's there and that height for a reason. More to the point, every manufacturer would reduce the height just to save money on materials if they could.
Tell you what, you may as well just remove it completely instead of messing with it.
Me, I just crank the knobs, pull the pins, and the ROPS hinges down just fine for driving into the garage. Not worth my life to mess with what works.
   / Lower ROPS #13
The height of a ROPS is actually determined by U.S. federal regulations.
Roll-Over Protective Structures - 70:76979-77025
   / Lower ROPS #14
I have a 2 piece rops on my NH TC30 that is joined and pinned above the seat. I want to lower it 5-6 inches so I can drive it into my barn without a worry- 1.5" clearance now. I thought to cut the rops on either side, remove the unwanted length, and insert a piece of square tube, pin it, and slide the top of the rops down onto these pinned square tubes. Then pin the top to that. I don't worry about warranty- tractor is 11 years old. Will this work and still keep the rops functional?
If there is a clearance right now of 1.5", why do anything?
   / Lower ROPS #15
If I had 1.5 inches it would be great ,, mine is 3 inches negative and would take out the lower door panel...So, I take out the upper bolts and pull it off..I wish I could come up with a hinge design for the rops? I have studied others photos?
   / Lower ROPS #16
Go ahead, lower it. Most likely you'll never need it until you do.
But I agree, an inch and a half is a lot of clearance. I have one inch of clearance so I try not to bounce my tractor as I enter my garage. And if there is lots of snow I make sure it is clear before heading out which is easy given that the blower is always mounted in the winter. Neither is hard to do. I drive truck and have found that there are many bridges that have just an inch of clearance (I go very slow under those.) I know this because I have hauled a lot of oversize loads and I stop, when needed, and measure clearance (or my escort does.) I have also hit one bridge when I believed the posted height which had not been changed after the road below had gotten an overlay and I was under the statutory and posted height.
   / Lower ROPS #17
Nowhere here do I see anything about just HOW and WHERE OP uses his tractor. If his use is always on his property and his property is flat or has no slopes that would create a tipping or rollover situation and he wants to modify the ROPS, no issue. HOWEVER, if he is like me, and most of tractor operation is on flat surfaces BUT some is on slopes...I question the reason for the modification. And if anything above 20% is in a situation where his tractor MIGHT tip...NO, NO, NO. If clearance is an issue, much safer and practical to modify to a folding ROPS, as Gary Fowler points out.
About having a minimum of clearance...one issue: I have a pair of overhead garage doors on the barn I store my tractor in. Both use electric openers, and one of the openers is very prone to stopping the door it operates two or three inches from fully open. Since I have to fold the ROPS on my Deere to get thru the doors regardless, it's automatic to do so and I have no clearance issues. But if OP ever had the same situation where his door didn't open fully, it could be an expensive lesson.
   / Lower ROPS #19
A lot of the times I leave the ROPS on my Deere folded down because my property is 99% perfectly flat and/or has no real slope that would present a tipping hazard, and I have to mow under a LOT of trees that the ROPS hits when upright.
I really wish there were a way the makers could design a ROPS that would work like an air bag, like having the top section telescoped into the bottom section all the time, with a sensor to trigger the top section to extend and lock into place if a rollover sitation begins.
Don't laugh but I do have some weird ideas !!!
   / Lower ROPS #20
They are actually working on this right now, because there are numerous accidents, involving tractors that did not have the ROPS extended.
You might not like it, when you see how much it adds to the cost of the tractor.
If the government gets their way, all will have to pay for those who can't be bothered to put the ROPS up.
http://www.cdc.gov/niosh/awards/hamilton/pdfs/deploy-rops.pdf
2005 Case IH 2062 Flex Draper Header (A50657)
2005 Case IH 2062...
2018 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A51222)
2018 FREIGHTLINER...
2004 KENWORTH DIGGER TRUCK (A50854)
2004 KENWORTH...
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2017 F-550 Bucket Truck (A51039)
2017 F-550 Bucket...
12-Wheel Pneumatic Pull-Behind Asphalt Compactor (A49461)
12-Wheel Pneumatic...
