lower arm switch burned out?
/ lower arm switch burned out? #1
BrettW
Platinum Member
now in S.C.!!
Yanmar FF205D
Hi,
I was using the switch that raises and lower one of the arms on my 3pt hitch. It got really hot and stopped working. Does anyone sell a replacement switch or have any recommendations. I took the unit off and all the solder joints are still good.
thanks, brett w
/ lower arm switch burned out? #2
Brett, others have replaced the OEM switch with a 3-way self centering switch, or as you saw on mine just straight hydraulic. You should be able to find the switch at Radio Shack.
Hi Don,
How is it in Md? I'm in SC now. Anyway, as you said a few months ago," that switch will not last long. " Would the guys at Radio Shack be able to get me something heavy enough to do the job? I was using it a lot when it went dead. So you think the problem is in the little switch itself. thanks, brett
/ lower arm switch burned out? #4
Brett, from earlier posts that seemed to be the problem. Maybe someone here will answer who has changed the switch. You might try Aaron at Hoye tractor for a replacement switch. It MAY not be too expensive. I would try for the heaviest duty switch available, and replace as needed.
/ lower arm switch burned out? #5
Brett
please post a picture of your switch that you need
I have 2 FX24-D parts tractors here & they both have the switches
Thanks Ernie
503-829-9170
Will do ASAP, thanks , bw
Athey 7-12 Force Feed Loader (A62679)
Athey 7-12 Force...
New/Unused Landhonor 16ft x 13ft Metal Carport (A65583)
New/Unused...
2017 ISUZU NPR 18 FT  BOX TRUCK (A59905)
2017 ISUZU NPR 18...
2007 INTERNATIONAL 7400 SBA 4X2 VACUUM TRUCK (A63276)
2007 INTERNATIONAL...
(15) Polyethylene Road Bed Protection Pads (A60462)
(15) Polyethylene...
Adams 350T 10T Tender (A61307)
Adams 350T 10T...
