Lower 3pl arms quick hitch options?
/ Lower 3pl arms quick hitch options? #1
tractor240
Massey 240
Massey 240 lower arms p/n 1869289M91
Hopeless getting those arms lined up...takes forever, back an inch, forward an inch, back again, up down up down.
Every time I think...there must be a better way.
So far, options seem to be:
CBM weld-on hooks
Walterscheid weld-on hooks
PAT'S no weld hooks
Frame type though without being width adjustable I don't understand how they can be universal for most attachments.
Any other suggestions? recommendations? things to avoid?
Thanks
/ Lower 3pl arms quick hitch options? #2
There are lower 3 point arms that the ends slide in and out my TC45 has them. I really like them and they make hooking up implements easy.
Kubota and John Deere have them and likely others too, the attached pic is of the Kubota ones.
The MF 165 had lower 3 point arms that would adjust some on the implement end.
/ Lower 3pl arms quick hitch options? #3
Weld on lower link hooks for sure. You won't regret it and it a quick hitch that actually works, works well and very easy to use.
The frame type quick hitch, more often than not just required some modification of some sort either at the frame or at the implement side. Then, you still get a frame in the way to connecting a PTO shaft. There is also the unrealistic expectation that you can hook up implements without leaving the seat. That's maybe the case for a box blade or a landplane but just about all the others it won't work that way. There is always a stand to fold, a PTO shaft and/or hydraulic hoses to connect and adjustments to be made.
PATs, while convenient since it doesn't require welding, it removes the ball joint of the 3 pt hitch which is key for the 3 pt hitch linkage to work properly. Under certain conditions, will put the pins on a bind and create issues. For the same reason, using implements with narrower or wider lower pin distance can cause binding issues.
There have been quite a few users of this forum changing to the lower link hooks, even trying all the other systems and they all say it's well worth.
I will always recommend the lower link hooks 200%.
/ Lower 3pl arms quick hitch options? #5
Agristore has them. Or you can purchase them from me.
I recommend the cat 1-2 size for your tractor.
You will want a set of implement balls for each implement, so get a count of your implements and what type of connections they have, stud or clevis types.
Here is a source for AMA (Italian made) hooks in the US: Weld-on Ends
The Walterscheid seem to be very expensive.
The CBM are about double the price of the AMA and up close the build quality (welding) looks about the same. They are both Italian brands.
CBM:
AMA:
/ Lower 3pl arms quick hitch options? #8
This is only my opinion.
I don’t think any of the other products besides the extendable arms eliminate the alignment issues when hooking up 3 point implements.
What use to take longer amounts of time and risk straining my back are now a five minute job or less including PTO driven implements.
One thing you have to do is keep things like PTO shafts and connectors lubed.
I get what your are saying however I suspect that my clunky old 46 year old tractor just doesn't do fine adjustments unlike perhaps more modern tractors such as yours. Either back and forward or 3pl up and down, it's totally hit or miss/sheer dumb luck if you happen to position everything just right to get that pin and ball lined up. The arm extension really only helps in one direction and with only one adjustment that I can see, the chances that it will line up is almost as small with or without the extension. Plus that Bareco part (16) is discontinued and Google gave me no hits for Massey 240 extendable link arms.
It seems that whilst not a perfect solution, the weld-on hooks are the least worst option and certainly better than the current situation.
/ Lower 3pl arms quick hitch options? #10
I get what your are saying however I suspect that my clunky old 46 year old tractor just doesn't do fine adjustments unlike perhaps more modern tractors. Either back and forward or 3pl up and down, it's totally hit or miss/sheer dumb luck if you happen to position everything just right to get that pin and ball lined up. The arm extension really only helps in one direction and with only one adjustment that I can see, the chances that it will line up is almost as small with or without the extension. Plus that Bareco part (16) is discontinued and Google gave me no hits for Massey 240 extendable link arms.
You’re not going to find a readymade solution for extending lower arms.
That said if you measure yours and and post the measurements. I could measure mine to see the differences.
With that information and maybe some from JD and Kubota owners you might find an another manufacturer’s extending lower arms that are compatible.
/ Lower 3pl arms quick hitch options? #11
The "hooks" are the best way to go. I have them on my 8050 and hookups are much simpler. I awaped from my back blade a heavy 10 footer that is cat 2-3 to my ditch bank flail which is cat 1-2 the other day. They are about 3 inches different in width so I did have to adjust the width as I backed into the mower but other then that a piece of cake the hydraulic and pto connections took way more time and effort then the lift arms and top link.
/ Lower 3pl arms quick hitch options? #12
/ Lower 3pl arms quick hitch options? #13
I welded Pats on my big tractor and have issues with different size implements, cat 1 to cat 2 are different widths.
I got a set of European ends that need to be welded on to fix the binding issue.
Slip on Pats that the compact tractor has work good for easier hookups. There is a little slack where they pin through the ball, enough to make hookups easier.
I will say with the Pats adjustment bar on the lower links, I am able to lock the lower pins in before crawling off most times.
/ Lower 3pl arms quick hitch options? #14
In another thread I mentioned having a QH for about 20 years without using it. The current L4240 has telescoping lift arms and telescoping stabilizers. Those two features USUALLY make connecting implements fairly easy. When I do run into uncooperative attachments a 48" pinch bar helps line things up.
