Mowing lower 3ph without mower going down?
   / lower 3ph without mower going down? #1
Anonymous Poster
Epic Contributor
I'm a new owner (with the bank) of a BX2200. Is it possible to lower the 3ph with a box blade without the mid-mount mower going down also?
thanks,
oj
I think I asked that backwards. Can you lower the mower with out lowering the 3ph?
thanks,
oj
   / lower 3ph without mower going down? #3
Raise the deck to its highest position then turn the cutting height control knob to "TOP". It will still go down -- but not much. If you need more ground clearance you can set the guage wheels to the lowest hole.
Huck
   / lower 3ph without mower going down? #4
No, Ozark John, you cannot. You could fix a chain to hold up the rear 3 point but on the BX they are operated together by the same lever. I usually remove the mower deck when using rear implements. Besides all that weight on my lawn area when mowing just compacts my soil worse than it is already. J
2018 Ford Ecosport S SUV (A50324)
2018 Ford Ecosport...
2019 Ford F-350 4x4 Ext. Cab Palfinger PSC 3216 4,000LB Crane Service Truck (A50323)
2019 Ford F-350...
2011 Manac 36245B30 45FT T/A Walking Floor Trailer (A50323)
2011 Manac...
Wolverine Mini Skid Steer Grapple (A50515)
Wolverine Mini...
2001 INTERNATIONAL 2574 6X4 (A51406)
2001 INTERNATIONAL...
2016 Chevrolet Sonic LS Hatchback (A50324)
2016 Chevrolet...
