Lower 3PH Snowblower
   / Lower 3PH Snowblower #11
You have two sets of holes on either side of the blower. Remove the lift pins and use these two holes to bolt a plate, (at least the same thickness as the frame), that has been drilled to except the pins that you removed and attach them at a higher location that would lower the blower. No welding. Just watch your PTO shaft angle.
This simple fix seems to work. Two pieces of 3/8" x 2" x 8" flat stock with three 7/8" holes. The middle pin was where I was hooking up.
Probably wont need them but I will probably weld in pipe spacers around the two bottom pins.
   / Lower 3PH Snowblower #13
Looks like a great fix. Good on ya!
   / Lower 3PH Snowblower #14
Great, you found a fix.:thumbsup:
Can't say for sure, but I think you may need the spacers.
Nice chains.
2016 Isuzu NPR-HD 24ft Box Truck (A50323)
2016 Isuzu NPR-HD...
2002 International 9200i Truck (A52748)
2002 International...
2012 INTERNATIONAL DURASTAR 4400 4X2 SERVICE TRUCK (A51406)
2012 INTERNATIONAL...
Mulch Spreader (A50120)
Mulch Spreader...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A52748)
2006 Magnolia Dry...
Komatsu Midi Excavator (A51691)
Komatsu Midi...
