Low idle rpm
   / Low idle rpm #1
1952ar
1952ar
Hello everyone! I just became a member, so please be patient with me!
I have a 1952ar which is mostly my snow plow tractor. I just installed a carburetor kit with the hopes of smoother running. I have it up and running but would like to have more rpm痴 because it feels like it is running slow when my throttle is fully engaged.
I知 looking forward to hearing about other vintage tractor problems and solutions.
   / Low idle rpm #2
Sounds like the throttle linkage needs to be adjusted. You can disconnect the throttle linkage and work the carb by hand to see if that is it. Also may need to adjust the carb mixture screws.
   / Low idle rpm
First of all. Thanks for such a quick response.
I will give that a try.
   / Low idle rpm #4
How many rpm are you trying to get? and what rpm do you have now at wot ??
:welcome: to TBN
   / Low idle rpm
I don't know how many RPM I'm looking for. i just feel like my tractor is not running quite fast enough. I don't have a gauge to indicate my rpm.
   / Low idle rpm #6
Those two-lungers don't run very high rpm.. less than 1000 rpm so you might want to get the tool to find out where you are at and where you want to go so you don't over-crank it.
   / Low idle rpm #7
IDLE rpm
   / Low idle rpm #9
I missed that in the subject line. But the OP seems to indicate trying to get higher rpm. Sorry, my bad.
Maybe not so much. ... One looks for coherence between title and post. With the brevity its not really clear.
Klemmfix Qwick Curb (A51692)
Klemmfix Qwick...
2020 Isuzu NPR Heil Rear Loader Garbage Truck (A52377)
2020 Isuzu NPR...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
2018 FORD F-550XL SERVICE TRUCK (A51406)
2018 FORD F-550XL...
2008 Freightliner B2 School Bus (A51692)
2008 Freightliner...
