Low compression
/ Low compression #1
jimjumper
Hemet, CA
Yanmar 240D, 8N Ford
Was given a 240D that had been started a few times using starting fluid. Compression is really low, as might be expected. Ive used it during the last 2 summers getting it started by using a block heater for about an hour to get it to starting temp. It has good power and not much blow by after its warm. Am I doing more damage continuing to use it? Or should I just run it till it won't start anymore or I get tired of it being slow starting and then rebuild it?
/ Low compression #2
If there is not a broken ring bouncing around in there or a piston slapping around with half a ring it's not doing anyting. I would keep running it till you can't get it started anymore. It's possible that the starting fluid didn't do anything and that it was just worn-out anyway. It doesn't always blow the heads, crack rings and blow holes in the Pistons, just does it more often than not.
Deutz DX140 Tractor (A66285)
Deutz DX140...
2022 EZ-GO ELITE...
2009 CHEVROLET 3500HD 4x4 PICKUP TRUCK (A59912)
2009 CHEVROLET...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
ATS Mini Excavator (A66408)
ATS Mini Excavator...
New/Unused Landhonor Gantry Crane (A65583)
New/Unused...
