Love At First Sight
/ Love At First Sight
I use WIX on my DK35SE. One oil filter issue is that the length space is limited when you look at filters that are candidates. Your a long ways from a hydraulic filter. Engine "size" vs. hp vs. torque is a better discussion than cc's or ci's. In a tractor torque & traction are the supremo factors.
I hope to track down a Wix filter in the future. Might be the same one as on the CK2610 since they may use the same or very similar engines.
Went out to the garage to settle the engine size controversy. Right on top of the cover it said it was 1.647 L with injector timing of 16 degrees BTDC.
That's a 100 CID engine which should provide more torque than a smaller displacement engine
ETA:
This site sez it's over 77 ft-lbs of torque. I think that's pretty good for that size tractor. Kubota says the engine in the L2501 has 58 ft-lbs of torque. I think the Deere Yanmar is around 65 lb-ft . I don't see the Kubota figure as accurate. Got to be more
If all this is true, I is impressed
/ Love At First Sight #43
Regarding the "zerks" query, I didn't know there was a difference between British and N American only that in Britain we call them "nipples". It's sexier.
However, I have an American (Lincoln?) grease gun and it fits the nipples on my Kioti (European model - CK2810). Hope that helps. It also fits the nipples on my British JCB 8025 excavator.
/ Love At First Sight #44
The manual should have a dedicated section that shows all of the grease points. Yes the loader will have more than the tractor, but there are usually still a few on the tractor (front axle as an example on mine).
I am not sure which zeros Kioti uses sorry. Maybe someone else here will.
My 3510 user manual does show them. However, there are gear and hst models plus base and se. I don’t know how many variants of a cx2510 may be out there but the manuals kioti gives are generic. Mine shows things that don’t exist on my model.
/ Love At First Sight #45
There's a recent thread somewhere on here that is about zerks. I googled zerk type chart and came up with several versions I didn't know about. Whatever is on Kioti, my grease gun fits it and everything else I've ever owned-go figure on that huh?;)
Kubota's tricky on numbers as they all are at times.
I'm finding that i have to go up several increments of tractor size to around 50hp to even begin to match my Kioti DK 35SE in engine torque, loader capacity and overall weight. I'm also finding that there lots of lesser machines and similar machines but the larger ones where I gain some umph are high hours serious farmer tractors that I don't want to herd around or pay for.
Your 3510 will do most anything a hobby farmer needs.
/ Love At First Sight #46
There's a recent thread somewhere on here that is about zerks. I googled zerk type chart and came up with several versions I didn't know about. Whatever is on Kioti, my grease gun fits it and everything else I've ever owned-go figure on that huh?;).
My wife asked me what I was doing.
I said I was on TBN. She took my phone, looked, read and asked “what is a zerk”?
I told her and showed her one on the tractor.
She stated at me a while and said “all you guys are on your phones talking about grease and these zerk things in a chat room”? Well - yea - sort of.
She shook her head and said never ever never make fun of anything she ever does again. That includes getting her toenails polished.
We have reached a new low gentlemen!
MoKelly
/ Love At First Sight #47
Thats fine. Just look for all of them on your machine and circle them in the manual, that way you know what you have. Then next time it will be easy! Just double check them the first time.
/ Love At First Sight #48
MoKelly
Good thing you are here in the USA. Some countries call zerk fittings "nipples". That may have required a little more explaining about what you were really talking about and possibly a level of disbelief when you were trying to show her where nipples are located on a tractor... :unsure:
/ Love At First Sight #49
You’d be correct on trying to explain that!!!
MoKelly
/ Love At First Sight #50
Sitting outside on a patio in Moab looking at the beautiful morning sun over the red rocks on my vacation. I’m already contemplating my return home to about 150 zerks needing to be greased.… :rolleyes:
2nd cutting is waiting for me…..:cry:
/ Love At First Sight #51
Think how much better it would sound if you were returning home to 150 nipples to be dealt with . . . . .
/ Love At First Sight #52
I knew Kansas farmers who had in the area of 200 tires on the ground mtd on various machines, trailers and so on. There's nipples then theres tires, engines, buildings, critters, kids, etc., etc..
/ Love At First Sight #53
U.T., I'll add my congrats on the new tractor! 👍 Enjoy as much seat time as you can in MI this summer. I suspect you're really going to miss that machine when you're back in Florida this coming winter! :)
/ Love At First Sight #54
Congrats (y)
You may want to check nuts and bolts make sure there tight.
Not to rain on your parade but the dealer I bought my 2014 CK2510 from F'ed up the assembly. The Rops wa on backwards ( I found out when I tried to fold it) and they stripped the mounting bolts (I discovered when I tried to mount it properly) and put smaller bolts and nuts through the striped holes.
There were about 6-8 errors in assembly and I had to fight tooth and nail with Kioti to get it fixed.
I've got over 700 hrs on it and love it.
Best of luck.
/ Love At First Sight #55
BTW my 2014 does use British zerks/nipple. The difference is it's a tapered thread.
And you WILL be replacing some. Get some zerk covers to keep them clean between lubing, which should be very frequent for the FEL.
/ Love At First Sight #56
I broke one, had to buy a package at Napa....that was ok I now have an assortment!☮✌🏻
BTW I use a K and N air filter on my CK25 last filter I will ever have to by....just wash dry and reuse!!!
/ Love At First Sight #57
Those K&Ns let in waayy too much dirt and dust for tractor use.
/ Love At First Sight #58
I like the inner&outer filter combos because I can knock the dust off of the outer one / blow it out and see that the inner filter is still spotless.
Back in the day when I had a K&N for my car I wasn't impressed with the effort it took to clean it vs the cost of a good disposable and I couldn't feel any of the alleged performance gains.
/ Love At First Sight #59
Second that on checking ALL bolts on that tractor especially the wheel lug bolts and all mounting frame bolts for the FEL. Recheck them all again after about 50 hours of operation. When I got my LS, I found several bolts that were not even finger tight. Pay close attention to any bolt that looks like it may be hard to get a socket on. Those were the ones I found loose (accessible only with an end wrench). Lots of tractor owners have completely ruined back rims because the bolts got loose but dont forget to tighten the front ones also.
Whenever I buy something new, I go over every bolt and lube point to make sure they are tight and that gear boxes are full of oil and grease zerks have been greased. A little extra grease wont hurt a thing.
Unused 2022 Loftness 14CFISV3 Auxiliary Hydraulic Oil Cooler Skid Steer Attachment (A66734)
Unused 2022...
PALLET OF MISC MOTORS AND PARTS (A67714)
PALLET OF MISC...
2014 MAGNUM TRAILER (A68842)
2014 MAGNUM...
24Wx25Lx12H Two Car Metal Garage | Durable Metal Garage
24Wx25Lx12H Two...
2021 BOBCAT T76 R-SERIES SKID STEER (A65056)
2021 BOBCAT T76...
2018 Deere 650K LGP (A64127)
2018 Deere 650K...
