Loud noise coming from Maschio finish mower
   / Loud noise coming from Maschio finish mower #1
Axeman
Whidbey Island, Washington state
GC2300
I have only used my Maschio finish mower a few hours and a couple of days ago I was cutting some tall grass and didn't see the low stump that was covered up by the grass. The mower went over the stump and when it came off it was making a rather loud clacking sound. It appears to be coming from the gear box but I'm not certain. I know this is a vague description and I really guess it's just a shot in the dark here that someone might have run across this before but I thought I'd ask the question before I go to all the trouble of loading the mower up and taking it into the dealer for service.
   / Loud noise coming from Maschio finish mower #2
Hope not!
Did you raise up the unit and spin the blades by hand? (you may have to detach the drive shaft) You may find the stump the bent the deck housing a little, causing a blade tip to rub against it.
Good luck!
   / Loud noise coming from Maschio finish mower #3
Did you find the problem?
Other than this, how do you like the mower? I have been shopping for a finish mower and have been trying to get opinions on the various makes available.
2010 Case 650L Crawler Tractor Dozer (A50322)
2010 Case 650L...
Kubota RTV500 (A47384)
2015 Ford F150 Crew Cab Pickup (A50323)
2015 Ford F150...
1 T Truck Dump Bed (A50515)
1 T Truck Dump Bed...
2014 Gillig 31+56 Low Floor Bus (A50323)
2014 Gillig 31+56...
2018 Nissan Pathfinder SUV (A50324)
2018 Nissan...
