Loud noise coming from Maschio finish mower
   / Loud noise coming from Maschio finish mower #1
Axeman
Whidbey Island, Washington state
GC2300
I have only used my Maschio finish mower a few hours and a couple of days ago I was cutting some tall grass and didn't see the low stump that was covered up by the grass. The mower went over the stump and when it came off it was making a rather loud clacking sound. It appears to be coming from the gear box but I'm not certain. I know this is a vague description and I really guess it's just a shot in the dark here that someone might have run across this before but I thought I'd ask the question before I go to all the trouble of loading the mower up and taking it into the dealer for service.
   / Loud noise coming from Maschio finish mower #2
Hope not!
Did you raise up the unit and spin the blades by hand? (you may have to detach the drive shaft) You may find the stump the bent the deck housing a little, causing a blade tip to rub against it.
Good luck!
   / Loud noise coming from Maschio finish mower #3
Did you find the problem?
Other than this, how do you like the mower? I have been shopping for a finish mower and have been trying to get opinions on the various makes available.
2017 Yale GLC050VX 3,500 lb LPG Forklift - Powershift, Aux Hydraulics (A52128)
2017 Yale GLC050VX...
2014 UTILITY 53X102 DRY VAN TRAILER (A50046)
2014 UTILITY...
1985 Big D Pintle Hitch Trailer (A50514)
1985 Big D Pintle...
2007 Amkus Rescue System (A50322)
2007 Amkus Rescue...
2006 GMC C7500 DUMP TRUCK (A51406)
2006 GMC C7500...
Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
Bad Boy Outlaw XP...
