Loud bang and the clutch stopped working ....
   / Loud bang and the clutch stopped working .... #1
Navvet
NC
Mahindra 4025 Bobcat S185 John Deere X495 John Deere 6x4 Gator
Mahindra 4025 4wd with 250 hours on it. Been a great tractor so far.
Was out on my road today doing some minor work, 1st gear, low range, 1200rpm, when I heard a moderately loud bang.
Pushed the brake and clutch and nothing happened. Tractor kept on rolling.
Slowed down when I reduced the throttle and finally stopped when I popped the tranny out of gear.
No obvious external damage and the clutch still controls the PTO, just won't disengage the transmission.
I figure I’ll start to split the tractor to check for internal damage in the clutch housing.
Any tech guru's have any suggestions on what to look for ?
   / Loud bang and the clutch stopped working .... #2
Before splitting, is there a inspection plate in the bottom of the bell housing?
Pto probably works of a switch on the pedal.
No inspection plate ...
The Transmission and the PTO are a dual clutch system off of a single pedal. Upper half of the pedal travel is the transmission and the lower is the PTO (so you can change gears without interrupting the PTO operation).
   / Loud bang and the clutch stopped working .... #4
I see, I was thinking it had independent PTO not live. Hate they did not put a inspection plate. Not that it would not change the need to split but at least you would have a idea of what you needed.
Yea, was hoping to find some one who has seen a similar problem and might have some tips.
Usually a good idea to pick the brains of those with more experience ....
Almost got the tractor ready to split, can't wait to see what's broken ...
   / Loud bang and the clutch stopped working .... #7
My 4110 is an independent PTO so no dual clutch but when my tractor had the same symptoms 3 times over the years it was 1 of the pressure plate thru bolts snapped - not the bolts that hold the plate to the flywheel, one of 3 bolts that hold the face plate against the springs between the cover and also hold one of the fingers the release bearing rides on. I tried to find just a new bolt, even at a clutch rebuilder in Nashville but no luck. Had to get a reman pressure plate.
   / Loud bang and the clutch stopped working .... #8
Maybe: Kentucky Driveline and Clutch-they are just south of Louisville, KY
I think I found my problem, surprisingly I didn't see any thing else damaged.
   / Loud bang and the clutch stopped working .... #10
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2017 POLARIS RANGER 570 4X4 PROSTAR UTV (A51406)
2017 POLARIS...
2003 STERLING M6500 ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
Kubota SVL65-2 Open Station Rubber Block Tread Skid Steer (A52128)
Kubota SVL65-2...
2013 Chevrolet Caprice Sedan (A50324)
2013 Chevrolet...
2015 CATERPILLAR 305E2 CR EXCAVATOR (A51242)
2015 CATERPILLAR...
