Lots of seat time this weekend
   / Lots of seat time this weekend #1
DaveNay
Platinum Member
Waterman, DeKalb County, Illinois
John Deere 855 MFWD; Oliver 1850 Gas
I got plenty of "seat time" this weekend. One of our horse paddocks had pretty much turned to soup this week, and I went in there to do a little drainage work with the FEL. Well, it turns out that this paddock happens to be an old cattle yard, and that "soup" on top was....well, I think you can figure it out. Twelve hours work over two days later, and I have a wonderfully clean paddock. There ended up being a layer of gravel about 6-8 inches below the surface, so I took on the task of removing the entire top layer down to that gravel. I calculate I moved about 180 yards of errr.....compost /forums/images/graemlins/grin.gif.
Needless to say, my butt is sore, and my tractor is a mess. I did conclude that as soon as finances allow, I need to investigate a set of ag tires for my tractor, the turf tires are nice in the summer for mowing, but not adequate for this type of work. Also, even though I tried to keep my rear blade on for the weight, it's not enough. I think it is time to do the block of concrete and a few pipes trick for a 3PH counterweight.
I also think I am going to use this as an excuse to buy a pressure washer finally /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif My ony question is, is a pressure washer safe on my tractor? The last thing I would want to do is start removing paint instead of dirt.
Dave
   / Lots of seat time this weekend #2
The pressure washer is a tracor's best freind. I just keep it back for the painted areas. it's great for the mower deck and loader.
   / Lots of seat time this weekend #3
</font><font color="blue" class="small">( My ony question is, is a pressure washer safe on my tractor? )</font>
Be careful around seals, like on your axles.
   / Lots of seat time this weekend #4
Go for the power washer but also consider an air tank. The air tank and hose with a long nozel will get those hard to reach places clean.
PJ
   / Lots of seat time this weekend #5
Most of the newer power washers are supplied with several spray tips with different spray angles. As long and you don't pick a nozzle with too steep of a spray pattern you should have no problems with your paint. My belief is that a heavy coating of mud or dirt acts like sandpaper grating on moving surfaces and that can't be good for any moving part. I have heard both pros and cons on the subject of using a washer on tractors so the final decision is up to you. I use a DeVilbiss unit myself and it will knock the mud off my TC-40D in very short order.
BOX OF SCHUMACHER 6A BATTERY CHARGERS (A51248)
BOX OF SCHUMACHER...
Electric Forklift Pallet (A50322)
Electric Forklift...
UNUSED LANHERO LDH-T460 STAND ON SKID STEER (A51247)
UNUSED LANHERO...
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A51248)
UNUSED WOLVERINE...
2022 DRAGON  130BBL VACUUM TRAILER (A53843)
2022 DRAGON...
2009 Skeeter SL190 19ft Boat with 21ft Boat Trailer (A51694)
2009 Skeeter SL190...
