Lots of seat time this weekend
   / Lots of seat time this weekend #1
DaveNay
Platinum Member
Waterman, DeKalb County, Illinois
John Deere 855 MFWD; Oliver 1850 Gas
I got plenty of "seat time" this weekend. One of our horse paddocks had pretty much turned to soup this week, and I went in there to do a little drainage work with the FEL. Well, it turns out that this paddock happens to be an old cattle yard, and that "soup" on top was....well, I think you can figure it out. Twelve hours work over two days later, and I have a wonderfully clean paddock. There ended up being a layer of gravel about 6-8 inches below the surface, so I took on the task of removing the entire top layer down to that gravel. I calculate I moved about 180 yards of errr.....compost /forums/images/graemlins/grin.gif.
Needless to say, my butt is sore, and my tractor is a mess. I did conclude that as soon as finances allow, I need to investigate a set of ag tires for my tractor, the turf tires are nice in the summer for mowing, but not adequate for this type of work. Also, even though I tried to keep my rear blade on for the weight, it's not enough. I think it is time to do the block of concrete and a few pipes trick for a 3PH counterweight.
I also think I am going to use this as an excuse to buy a pressure washer finally /forums/images/graemlins/wink.gif /forums/images/graemlins/tongue.gif My ony question is, is a pressure washer safe on my tractor? The last thing I would want to do is start removing paint instead of dirt.
Dave
   / Lots of seat time this weekend #2
The pressure washer is a tracor's best freind. I just keep it back for the painted areas. it's great for the mower deck and loader.
   / Lots of seat time this weekend #3
</font><font color="blue" class="small">( My ony question is, is a pressure washer safe on my tractor? )</font>
Be careful around seals, like on your axles.
   / Lots of seat time this weekend #4
Go for the power washer but also consider an air tank. The air tank and hose with a long nozel will get those hard to reach places clean.
PJ
   / Lots of seat time this weekend #5
Most of the newer power washers are supplied with several spray tips with different spray angles. As long and you don't pick a nozzle with too steep of a spray pattern you should have no problems with your paint. My belief is that a heavy coating of mud or dirt acts like sandpaper grating on moving surfaces and that can't be good for any moving part. I have heard both pros and cons on the subject of using a washer on tractors so the final decision is up to you. I use a DeVilbiss unit myself and it will knock the mud off my TC-40D in very short order.
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51248)
UNUSED SWICT 84"...
2020 DEERE 318G SKID STEER (A51246)
2020 DEERE 318G...
UNUSED HURRICANE 10' WROUGHT IRON SITE FENCE (A51248)
UNUSED HURRICANE...
2018 JLG 1644 4x4 15,600lb High-Capacity Rough Terrain Telehandler (A52377)
2018 JLG 1644 4x4...
2004 FORD F-650 SUPER DUTY DUMP TRUCK (A51406)
2004 FORD F-650...
UNUSED FUTURE FT15J EXCAVATOR (A51247)
UNUSED FUTURE...
