Lost my Curl/Dump Function on Loader Kioti DK50SE
/ Lost my Curl/Dump Function on Loader Kioti DK50SE #1
liberty2701
Platinum Member
Lakes region,NH
Kioti Dk50se hst
I also posted this over in the Kioti forum.
I was moving a lot of loads today and suddenly I lost my curl/dump loader function. The bucket is loose and will flop around. When I operate the joystick left and right I can hear it operate like it is dead heading. I decided to disconnect all hoses from the loader block and check for outlet pressure. On all four I get the correct PSI upon moving the joystick. On the third port from right I get pressure but only if I hold it in that position. As soon as I let go of the joystick it returns to zero PSI. The other ports do not return to zero until I move the joystick in the opposite direction. It seems like a lot of air is in the curl/dump cylinders. My hydraulic fluid is full. I have 700 hrs on the tractor. Is it possible I have a broken both cylinders? Any idea as to my next step?
I just had an idea and swapped the hoses on the loader block. The left right joystick works since the loader raised and lowered. The forward /back stick did not curl or dump. That tells me it is not in the joystick or loader block. It must be broken cylinders or an obstruction? Any ideas?
/ Lost my Curl/Dump Function on Loader Kioti DK50SE #3
End of one the hyd rods broke off or nut came loose inside or blown piston seals?
Maybe a chunk of piston seal is blocking a port or fitting internally?
I ended up replacing the qd couplers with new Pioneer ag couplers and it fixed the problem. The funny thing is that I replaced all the loader qd couplers 3 months ago with Discount Hydraulic Hose branded couplers. Not sure why they stopped working already but Pioneer are definitely a much higher quality and made in the USA. I am glad it was a simple fix.
/ Lost my Curl/Dump Function on Loader Kioti DK50SE #6
:thumbsup: good to here it was a easy fix , I've found Pioneer couplers to hold up very well actually I've never had to replace one.
2009 GREAT DANE 48' T/A FLOAT TRAILER (A65643)
2009 GREAT DANE...
2002 CATERPILLAR 963C CRAWLER LOADER (A65053)
2002 CATERPILLAR...
Mack Fuel Truck (A63688)
Mack Fuel Truck...
2003 Dodge Ram 4x4 Ext. Cab Pickup Truck (A59230)
2003 Dodge Ram 4x4...
2023 Unverferth 3PT 10 FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
2016 Land Rover Discovery Sport SUV (A61574)
2016 Land Rover...
