Lost chimney brush in flue solution
/ Lost chimney brush in flue solution #1
Eastinlet
Bronze Member
Central Adirondacks
Kubota L2850D
Thought it might be a good chance to clean the chimney owing to the mild weather. Have about a 25' block chimney that used to have 8 1/2 by 13" flue tile. Had a chimney fire that damaged the tile 15 years ago, so we relined the bore with 6" stainless tubing. The corrugated tubing makes a seamless tube from top to bottom. Insulation was poured around the tube to hold it in place. Owing to irregularities the tubing is not perfectly straight but meanders a little, something you can feel while brushing it. By the way, there is no cleanout... the pipe turns a fairly sharp 90 degrees into the cellar.
So standard procedure for years has been to climb up the roof, insert a plastic 6" round brush and then screw on fiberglass rod sections as the brush advances down the tube. Only this time was different, as my son was scrubbing with short strokes and had the brush and one section (we later learned) came unscrewed and stuck in the chimney about 14' down.
This is a real problem... how do you get a chimney brush out of a chimney? Tried a few things first: tried to drop a line and sinker down hoping to get a line through the brush to the chimney base. Sinker would not go through. We cable clamped a couple big hooks onto the rod and tried to snag the brush to lift it out. No go... could push the brush down a little and lift it up a little, but not effective. Plastic bristles and too much give.
After some discussion and prayer we came up with an effective solution and would like to share it. There are probably other and better ways, but this is what we did:
Hose clamped a 6' piece of 1/2" PVC pipe to a fiberglass chimney rod section. Found a 5" carriage bolt that just slipped inside the PVC pipe. Tied braided fishing line just under the bolt head and wrapped with duct tape. Inserted the bolt into the PVC (so only the head is visible). Held onto the line, inserted PVC end into the chimney, maintaining tension on the line as it descends. Screw on another rod, drop it and the line down, letting the weight of the rods be taken by the taut line. And so on. Always letting the weight of the rods be born by the line, which in turn was tied to the bolt inserted into the PVC pipe.
Son could feel the PVC pipe bolt carrier touch the brush, gave a push and the entire pipe unit pushed lengthwise through the plastic bristles. Continue pushing downward until well below the brush, release the line and the bolt fell free and rolled to the inside base of the pipe where I could reach it in the cellar. Extract the rods.
Again, the purpose of the PVC pipe was to hold the bolt captive so it could be pushed through the bristles of the stuck brush. Twine or rope would just sit on top of the brush so we pushed the roped bolt through the bristles and could then grab the bolt at the bottom.
With a line from the top, I tied another stouter line on the bottom end and he drew it upward. We now had a continous line so we could tie something on either side to either push or pull the brush in whichever direstion was easier. At the time we had not counted rod sections and noticed that a rod was attached to the brush, we thought that it was only a brush and that we could possibly even pull it downward... that of course would not have worked with a rod attached.
A line knot snagged on the brush (as it happened) and let us pull the brush upward with a little assistance from a hook attached to rods. But once the line was passed through it was all over with for the brush and we regained control of the situation. Otherwise had planned to attach a disk to the line and use it to pull the brush upward. Hope this could help someone in similar circumstances... punch a line through the brush and you will own it.
Chris Thompson
/ Lost chimney brush in flue solution #4
An Overshot type tool would let you thread back on to the lost brush.:thumbsup:
/ Lost chimney brush in flue solution #5
Sounds very complicated, but at least it worked. We have cork screw type retrieval tools, but it is a major PITA to get something stuck in a chimney.
You should have a tee in there. Also in the future if you can get a line down thru, you can use that to move the brush thru the pipe.
JB
/ Lost chimney brush in flue solution #7
You forgot the duct tape :p
Being a Red Green fan, I now use duct tape on the joints of fiberglass screw together rods like the chimney cleaner and wire fishes. Having had to retrieve pieces from chimneys, trailer tubing, barrels etc. I find it pays to put a safety tape on the joints -- of course hindsight is 20/20. -- Glad you were successful!
/ Lost chimney brush in flue solution #8
Hi all
Good inventive solution and thanks for the tip on how to fix a stuck brush.
I had a similar problem a few weeks ago. Instead of a brush stuck in a chimney I had a drill stuck in a fence post. Was drilling in horizontally into a 18 in dia post to make a hole for a gate fitting. Was using a 1/4 inch drill (about 4in long) with a series extension rod held by a grub screw. The rod slipped and stripped the hex end of the drill and so had a 4 in drill stuck 6 in into the post!
Took me ages to drill in from the other side accurately enough to hit the end of the drill so I could then hit out out with a metal rod and hammer.
Have now bought a long series drill.
Mike
Interesting replies. I appreciate learning that there are chimney sweep tools for removing stuck objects like brushes and animals. A stuck coon is in some respects a bigger problem than a brush if you think about it. I have never seen those tools before, and it looks like they aren't magic but make removal possible with a little cussing.
My particular chimney without a cleanout or tee is not uncommon in old homes. It is definitely not a good place to lose a brush (or a coon). I never thought this would happen to us since we have done this for decades without incident.
Studor has a good point, if nothing else secure your joints with duct tape, I will do that from now on. I suppose you could be ultra neat and drill a hole through each joint and slip a hair pin clip through, but duct tape is more my style.
My final thought is to drop a line down through into the cellar before lowering the brush. It's there is you need it and causes no inconvenience to the operation. I will be doing this.
/ Lost chimney brush in flue solution #10
Don't fret Santa will be along in a few days.:D
Sorry I Coulden't resist.
Good Evenin LBrown,
Or we could lower that white little fur ball pictured down the flue also to retrieve, although it wouldnt come back out white..;)
Sorry, couldnt resist ! :)
/ Lost chimney brush in flue solution #12
Good Evenin LBrown,
Hi scotty,
ya know at one time chimney sweeps would use a live goose to clean flues, probably mostly in Europe.
Tie a rope around it's neck and throw him down, the panicking goose would flap it's wings frantically, cleaning the passage.
Pretty cruel, not sure how long the poor goose would last in that role.
JB
/ Lost chimney brush in flue solution #14
This is getting off the response subject, but not as badly as sending the dog down the flue Scotty, anyway a couple years ago I got this expanding chimney cleaner with a rope tied to the top ring. The method of using it was to drop it down the chimney and then when you started pulling it back out the unit expands and scrapes the side of the chimney. Well it worked great for about ten pulls, by this time I am about fifteen feet down the chimney and when I pull the knot tie the rope to the rig comes on done.
So I call a close friend and fire chief of our local volunteer fire department and ask him what to do. His response was "be right over" next thing I know here comes a full line of cars and two fire trucks. Ladders out and about 7 guys on the roof. They dropped a chain with a rope tied to it and the chain worked it's self beneath the scraper and then they went into the clean out and attached a hook that caught the item and with two or three guys pull the darn thing out. It went immediately into the pile going to the dump. Yep there was a fire in the wood stove so it had to come out.
With that in mind one of the guys told me about this place in Maine that makes a stainless steel cable uint that is installed into the chimney and you can crank a brush up and down without climbing on the roof. Haven't bought one yet but here is the link to the place, tell me what you think?
Swift Chimney Cleaner - Why Risk A Chimney Fire?
/ Lost chimney brush in flue solution #15
At one tyme they may have sent small lads up the chimney??:
(Chimney sweep - Wikipedia, the free encyclopedia
Yup, Brutal conditions, child slavery was common in England up to the mid 1800's.
Have to try to imagine how important that fireplace and chimney were in the 16th to the 19th centuries. Life literally revolved and evolved around them.
JB
/ Lost chimney brush in flue solution #16
If anybody is looking for a good chimney brush, have a look at the sooteater SootEater
I have one and its great. You can clean from inside the house. Youll find yourself cleaning much more often do to the ease of use. (i clean mine in much less than an hour). it does a decent job and the rods are flexable. I can clean the black pipe down to my stove which is around a 90*. Price is less than $100
[ame=http://www.youtube.com/watch?v=ulrEYBKsHKc]Gardus: SootEater Chimney Cleaning System---Purchase At SteamBrite.com - YouTube[/ame]
New/Unused Wolverine Quick Attach 3 in 1 Frame (A61166)
New/Unused...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2001 Kubota L3300F 35HP Utility Tractor with Caroni TC710 6ft. Rotary Brush Mower Attachment (A59228)
2001 Kubota L3300F...
2004 Chevrolet 1500 Silverado Truck (A63116)
2004 Chevrolet...
New Three Point Hitch Trailer Mover (A61166)
New Three Point...
Woods Rotary Cutter (A63116)
Woods Rotary...
