Lost check link turnbuckle, can't buy at dealer--substitutes?
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #1
obscureflora
Bobcat CT4045
Tractor newbie here and I didn't tighten down the locking nut on my left check link arm (this is on a CT4045). Predictably, things got loose and I lost the turnbuckle. I can't get a replacement online, dealer is what I am finding your typical Bobact dealer and isn't very helpful beyond telling me its out of stock. The part in question is 7379628. Does anyone have a suggestion for a replacement?
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #2
Is it proprietary? Should be able to just get another one the proper length.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #3
I am probably the only one that doesn't know what the left check link turnbuckle is?
#9 is what I need. I called it a check link because that's what bobcat calls it. As to it being proprietary, I don't know. I bought what tractor supply had and it doesn't fit. Stuff I've seen online looks either incompatible or flimsy. Ideally I would buy the real thing but this is not currently possible.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #5
Depending on your tractor's age, Bobcat sold rebadged and painted Kioti built machines. You might try a Kioti dealer for the turnbuckle.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #6
Amazon has 22 pages of them. Some are stainless steel. You might look there too. :cool:
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #8
If your a collector of junk like me and like to tinker make your own/ had some cheap old binders laying around works great on a 30+ year old working tractor.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #9
I've always heard them called - 3-point arm turnbuckle. I'll guess that they ARE a proprietary item. If you had the exact part number you MIGHT find the correct one amongst the many on Amazon. Otherwise - make one up out of what you can find at the local hardware store. Order a complete new replacement unit from your dealer - and wait, wait, etc.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #10
Couple eye bolts, some chain & a turnbuckle.
Seems pretty easy to me.
Made a pair for my Ford 2N that way.
They work just fine.
Kenworth Tri Axle Dump (A47384)
Kenworth Tri Axle...
2018 E-Z Beever M12R Towable Brush Chipper (A50322)
2018 E-Z Beever...
378645 (A51573)
378645 (A51573)
2016 Tesla Model S 85D Long Range AWD Sedan (A51694)
2016 Tesla Model S...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
