Lost check link turnbuckle, can't buy at dealer--substitutes?
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #1
obscureflora
Bobcat CT4045
Tractor newbie here and I didn't tighten down the locking nut on my left check link arm (this is on a CT4045). Predictably, things got loose and I lost the turnbuckle. I can't get a replacement online, dealer is what I am finding your typical Bobact dealer and isn't very helpful beyond telling me its out of stock. The part in question is 7379628. Does anyone have a suggestion for a replacement?
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #2
Is it proprietary? Should be able to just get another one the proper length.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #3
I am probably the only one that doesn't know what the left check link turnbuckle is?
#9 is what I need. I called it a check link because that's what bobcat calls it. As to it being proprietary, I don't know. I bought what tractor supply had and it doesn't fit. Stuff I've seen online looks either incompatible or flimsy. Ideally I would buy the real thing but this is not currently possible.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #5
Depending on your tractor's age, Bobcat sold rebadged and painted Kioti built machines. You might try a Kioti dealer for the turnbuckle.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #6
Amazon has 22 pages of them. Some are stainless steel. You might look there too. :cool:
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #8
If your a collector of junk like me and like to tinker make your own/ had some cheap old binders laying around works great on a 30+ year old working tractor.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #9
I've always heard them called - 3-point arm turnbuckle. I'll guess that they ARE a proprietary item. If you had the exact part number you MIGHT find the correct one amongst the many on Amazon. Otherwise - make one up out of what you can find at the local hardware store. Order a complete new replacement unit from your dealer - and wait, wait, etc.
   / Lost check link turnbuckle, can't buy at dealer--substitutes? #10
Couple eye bolts, some chain & a turnbuckle.
Seems pretty easy to me.
Made a pair for my Ford 2N that way.
They work just fine.
2004 TRAILKING 101" X 53' STEP DECK TRAILER (A50459)
2004 TRAILKING...
Crosley 10ft. Hydraulic T/A Dump Trailer (A50322)
Crosley 10ft...
2018 KUBOTA SVL95-2S SKID STEER (A51242)
2018 KUBOTA...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
2020 HINO 195 CAB AND CHASSIS (A51222)
2020 HINO 195 CAB...
