lost 4 wheel drive
/ lost 4 wheel drive #1
jim hall
lyman me
kubota bx25
I have a bx 25 4 wheel drive not working I shift the lever and no 4 wheel.
/ lost 4 wheel drive #2
First thing to check is the drive shaft goin to the front axle. Unless yours has a cable that activates the 4wd, then check that first.
/ lost 4 wheel drive #3
Check your front drive shaft; these are usually driven by a "roll pin" which are not very substantial, and while your down there, check the linkage to be sure it is still connected
/ lost 4 wheel drive #4
I would check the handle to make sure it hasn't been bent or that a weld hasn't broke. Some of Kubota's handles are less than stout and have a tendency to bend giving you the full throw in the cover but not at the shift rod.
lost 4 wheel drive thanks guys but its not a rool pin,drive shaft, or the front wheel gears the lever works good shifts easy no welds broken shifting lever &rod move ok. jacked the front up put it in gear hold one wheel turn the other driveshaft turns sounds like agrinding noise in trans. 2009 bx 25.looking for answers.
4 wheel not working drive shaft, pins;lever ok slight grinding noise in trany when turning whels by hand.any ideas out there.
/ lost 4 wheel drive #7
I broke one of those roll pins. rear u-joint slipped off the tranny output shaft.
I also bent the rear diff lock linkage(don't know how).
I would go over all the 4wd shift linkage and make sure it is not tweaked, twisted, or bent. Not sure what your linkage looks like, but I would be tempted to disconnect at the transmission and work it by hand right at the transmission to see if that helps.
Other thing might try... does this tractor have a strainer on the hydraulics(my old B8200 did...). Remove the strainer, and look for big metal filings or chunks.
this is what iam talking about View attachment 267992 i took it to the shop i,ll let every one know what broke in a week or so.
(6) 8" X 8" TREATED TIMBERS (A63291)
(6) 8" X 8"...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2016 John Deere 6155R (A64119)
2016 John Deere...
2013 BMW 550i AWD Sedan (A61574)
2013 BMW 550i AWD...
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58216)
1999 WEST WIND...
