lost 4 wheel drive
/ lost 4 wheel drive #1
jim hall
lyman me
kubota bx25
I have a bx 25 4 wheel drive not working I shift the lever and no 4 wheel.
/ lost 4 wheel drive #2
First thing to check is the drive shaft goin to the front axle. Unless yours has a cable that activates the 4wd, then check that first.
/ lost 4 wheel drive #3
Check your front drive shaft; these are usually driven by a "roll pin" which are not very substantial, and while your down there, check the linkage to be sure it is still connected
/ lost 4 wheel drive #4
I would check the handle to make sure it hasn't been bent or that a weld hasn't broke. Some of Kubota's handles are less than stout and have a tendency to bend giving you the full throw in the cover but not at the shift rod.
lost 4 wheel drive thanks guys but its not a rool pin,drive shaft, or the front wheel gears the lever works good shifts easy no welds broken shifting lever &rod move ok. jacked the front up put it in gear hold one wheel turn the other driveshaft turns sounds like agrinding noise in trans. 2009 bx 25.looking for answers.
4 wheel not working drive shaft, pins;lever ok slight grinding noise in trany when turning whels by hand.any ideas out there.
/ lost 4 wheel drive #7
I broke one of those roll pins. rear u-joint slipped off the tranny output shaft.
I also bent the rear diff lock linkage(don't know how).
I would go over all the 4wd shift linkage and make sure it is not tweaked, twisted, or bent. Not sure what your linkage looks like, but I would be tempted to disconnect at the transmission and work it by hand right at the transmission to see if that helps.
Other thing might try... does this tractor have a strainer on the hydraulics(my old B8200 did...). Remove the strainer, and look for big metal filings or chunks.
this is what iam talking about View attachment 267992 i took it to the shop i,ll let every one know what broke in a week or so.
2001 Peterbilt 379 Tri-Axle Dump Truck (A59230)
2001 Peterbilt 379...
2012 INTERNATIONAL 4300 4X2 26FT NON CDL BOX TRUCK (A59911)
2012 INTERNATIONAL...
2007 Chevrolet Silverado\ Silverado Classic Pickup Truck, VIN # 1GCEK14X27Z181945 (A61165)
2007 Chevrolet...
2021 Ford F550 4X4 Service Crane Truck (A62613)
2021 Ford F550 4X4...
2015 International WorkStar 7500 T/A Dump Truck (A61573)
2015 International...
Miller Millermatic 212 Auto-Set MIG welder (A63689)
Miller Millermatic...
