Lost 3pt pin, replace with bolt?
/ Lost 3pt pin, replace with bolt? #1
Hookblock
WI
JD 4310
I was pushing snow with the bb and lost the the pin that connects the lower arm to the lift arm. It's a 5/8''x 2'' pin, can it be replaced with a bolt? Or just make a pin out of a bolt? And if I can, is a grade 8 the bolt to use? JD wants 14.00 for the pin, I have the bolt to make the pin. thanks
/ Lost 3pt pin, replace with bolt? #2
personally I wouldn't feel bad using the bolt with a locknut as long as the shoulder was bearing the load as opposed to the threads tearing something up--it may be stronger than the pin not sure. I certainly would not buy the JD part rather go to TSC or Atwoods later and get a pin for a couple bucks.
good luck
/ Lost 3pt pin, replace with bolt? #3
Grade eight in a pinch always works
/ Lost 3pt pin, replace with bolt? #4
You can make a lot of pins from bolt for $14. A grade 5 should be as strong as a pin.
Bill
/ Lost 3pt pin, replace with bolt? #5
Grade 5 or 8 bolt will work just fine. Lost a pin for the foldable ROP of my Kubota 3710. It was metric and Kubota wanted $45. Bought a metric bolt from implement dealer for a few bucks. Drill a hole for the key to slide in. Welded on a fancy D-ring to the head, painted and looked just like the lost one.
/ Lost 3pt pin, replace with bolt? #6
TSC has pins for something like 4 or 5 bucks, I bought some last summer but can't remember cost for sure, but it was in that ball park
/ Lost 3pt pin, replace with bolt? #7
Ya but isn't the JD one painted green.. Thats gotta be worth a few extra $$. :D:D:D
Wedge
/ Lost 3pt pin, replace with bolt? #8
I use grade 8 bolts with ny-lock nuts all the time for pin replacement. They cost about $2 each.
Thanks for the help the bolt I was going to use is a grade 8. 6 in long with a 3 in shank so no threades involved. Thanks
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2011 MIDLAND  GOOSENECK SPOOL TRAILER (A68842)
2011 MIDLAND...
AM GENERAL M1123 HMMWV 2 DOOR TRUCK BODY (INOPERABLE) (A67714)
AM GENERAL M1123...
PALLET OF FUEL TANKS (A68842)
PALLET OF FUEL...
Sandblast Skid (A68134)
Sandblast Skid...
(INOP) 2013 MACK ELITE LEU633 GARBAGE TRUCK (A65057)
(INOP) 2013 MACK...
