Loss of thumb
   / Loss of thumb #1
JWW10
John Deere 310SK
I have a 2015 310SK. When pivoting the operator seat to use the backhoe, at about the 90 degree position from the front, the auxiliary hydraulic light on the Sealed Switch Module goes out and stays out with the seat in the rear facing position and the thumb doesn’t function. All other backhoe functions work. When the seat is pivoted forward, the auxiliary hydraulic light comes back on at about the 90 degree position and the thumb functions. I replaced the seat rotator switch but nothing changed. Has anyone encountered this problem? I talked with a J-D service technician for 15-20 minutes today and he’s perplexed.
   / Loss of thumb #2
That’s a new one
   / Loss of thumb
That’s a new one
I was hoping it wasn’t 😊. I think the next step is figuring out how the auxiliary hydraulic light is connected with seat position. Thanks for the reply.
   / Loss of thumb #4
Here I thought you meant you cut your thumb off your hand lol
   / Loss of thumb #5
I presume the thumb valve is electrically operated so would look into how the power is supplied to the thumb control vs the seat swivel. Might be as simple as some relay not working but that is 100% pure guesstimate on my part.
   / Loss of thumb
Thanks for the input, I’ll check that out. Talked with a different heavy equipment mechanic today and he mentioned something similar, especially checking grounds.
2012 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A56138)
2012 FREIGHTLINER...
2024 Wanco WCTS-SM4A-730 800W Solar Integrator Trailer (A55851)
2024 Wanco...
CATERPILLAR H120S HYD HAMMER (A52707)
CATERPILLAR H120S...
2023 John Deere 8RX 370 Track Tractor (A53485)
2023 John Deere...
2022 CATERPILLAR 315GC EXCAVATOR (A52707)
2022 CATERPILLAR...
2018 Ford Transit Connect XL Cargo Van (A55852)
2018 Ford Transit...
