Loss of thumb
/ Loss of thumb #1
JWW10
John Deere 310SK
I have a 2015 310SK. When pivoting the operator seat to use the backhoe, at about the 90 degree position from the front, the auxiliary hydraulic light on the Sealed Switch Module goes out and stays out with the seat in the rear facing position and the thumb doesn’t function. All other backhoe functions work. When the seat is pivoted forward, the auxiliary hydraulic light comes back on at about the 90 degree position and the thumb functions. I replaced the seat rotator switch but nothing changed. Has anyone encountered this problem? I talked with a J-D service technician for 15-20 minutes today and he’s perplexed.
/ Loss of thumb
That’s a new one
I was hoping it wasn’t 😊. I think the next step is figuring out how the auxiliary hydraulic light is connected with seat position. Thanks for the reply.
/ Loss of thumb #4
Here I thought you meant you cut your thumb off your hand lol
/ Loss of thumb #5
I presume the thumb valve is electrically operated so would look into how the power is supplied to the thumb control vs the seat swivel. Might be as simple as some relay not working but that is 100% pure guesstimate on my part.
/ Loss of thumb
Thanks for the input, I’ll check that out. Talked with a different heavy equipment mechanic today and he mentioned something similar, especially checking grounds.
2007 John Deere 644J Articulated Wheel Loader (A59228)
2007 John Deere...
2012 DRAGON 130BBL VAC TRAILER (A58214)
2012 DRAGON 130BBL...
AGT Industrial M-DGR (A60463)
AGT Industrial...
2010 MAXEY WELDING 20 T/A GOOSENECK TRAILER (A58214)
2010 MAXEY WELDING...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55315)
2012 JOHN DEERE...
