Loss of speed
   / Loss of speed #1
Tzappia
Kubota L3940
I have a Kubota 3940 with 800 hours. Even while traveling on a road and it happens mostly going up hills, my Kubota rpm remains strong however my tractor loses considerable speed. I replaced my fuel filter. Any suggestions? I have an HST.
   / Loss of speed #2
If you are in high range, put it in the middle range instead.
   / Loss of speed #3
Have you checked the fluid level? Color? Smell?
When was the last time the fluid was changed?
Also, check your linkages for the speed control pedal.
   / Loss of speed #4
Do you have the stall guard on? If so it will reduce ground speed to maintain engine rpm.
If not then I would check that a brake isn't dragging, had this issue on a smaller tractor, easy way to tell is let it freewheel on a slight grade and see how well it rolls.
Sent from my SM-G715U1 using TractorByNet mobile app
   / Loss of speed
Thanks everyone. I'll recheck fluids and the stall guard.
   / Loss of speed #6
are your tires filled, apparently that will really slow you down on the hills
   / Loss of speed #7
I have a BX25D and the linkage from the hydrostat pedal back was missing a nut, I double nutted it and got all of my speed back. On the BX25D the connection was back by the hydro filter.
   / Loss of speed #8
Good to see your still making dust. :)
1992 Talbert 70 Ton Lowboy Trailer with Removable Gooseneck (A57024)
1992 Talbert 70...
2014 Ford F-550 4x4 Altec AT37G 37ft. Bucket Truck (A55852)
2014 Ford F-550...
2001 Ford Ranger Pickup Truck (A51694)
2001 Ford Ranger...
2007 FORD F-150XL TRITON TRUCK (A51406)
2007 FORD F-150XL...
48in Farm Jack (A55852)
48in Farm Jack...
Ford Metal Tailgate Art (A55853)
Ford Metal...
