losing power
   / losing power #1
dboose
Winston-Salem NC
2810 HST Mahindra
mahindra 2810 hst a lot of metal shavings in filter when hydraulic fluid was changed. after I changed fluid I blew a seal in the axle housing. repaired that. now the bucket will barely lift,and while pulling there is little power.can some one help. Iam about ready to shoot my tractor.
   / losing power #2
Has it been running long enough to get a lot of the air out of the system?
When I hear “blew a seal” I think over pressure. Was this an over pressure (not likely/possible in the axle) or was this simply a failed axle seal? Or maybe something else completely?
   / losing power
it was a failed seal, The metal shavings where brass looking.there is also a knocking noise
   / losing power #4
Should maybe pull screen out of trans and clean that.
2013 BIG TEX BIG TEX (A52472)
2013 BIG TEX BIG...
2015 KENWORTH T680 TANDEM AXLE SLEEPER (A52577)
2015 KENWORTH T680...
2004 IC Corporation 3000IC School Bus (A51692)
2004 IC...
Has Charger with it. (A51694)
Has Charger with...
LINK BELT LB-98 LOG LINE YARDER WITH MOTORIZED CARRIAGE (A52576)
LINK BELT LB-98...
