losing power
/ losing power #1
bob_wood
plainfield NH
kubota 4610, kubota 4200, JD 455, Toro 256E zero turn mower, Case 135 excavator, hydraulic dumpcart
My Toro Zero turn mower began missing / sputtering and losing power today. Only happens under load ( mower deck engaged / mowing uphill ) The engine is a Kohler Command Pro 26. I have a little over 600 hrs on it and have never changed the plugs or fuel filter so think I will do that in the morning. Anyone have any other suggestions as to what I should check ?? Thanks
Bob
/ losing power #2
How old is your gas? I've been having alot of trouble with the new ethanol mixed fuel in my small engine stuff. Had the same problem in my exmark 21". Changed the plug and put fresh 93 octane in and it seems to be fine. I used to buy 3 or 4 five gallon cans at a time, now I buy just one and use it as fast as I can. Anything I'm not going to use for a while I run out of fuel too.
Scott
/ losing power #3
Lotsa times water in the fuel will cause those symptoms..
soundguy
/ losing power
Thanks for the feedback guys ! I replaced the plugs and fuel filter today and my Toro is running good again. ;)
bob
Wooden Wagon Wheel Rocker (A61569)
Wooden Wagon Wheel...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
New/Unused Top Cat Quick Attach Stump Grinder (A61166)
New/Unused Top Cat...
CARRYALL 1700 UTV (A62130)
CARRYALL 1700 UTV...
Colombo Twin Master (A62177)
Colombo Twin...
2009 Ford F-150 Pickup Truck (A61568)
2009 Ford F-150...
