Losing power when warm. Air filter and fuel filtes changed. What next?
   / Losing power when warm. Air filter and fuel filtes changed. What next?
So it wasn't the fuel. I emptied the tank.
   / Losing power when warm. Air filter and fuel filtes changed. What next? #12
Check the vent for the tank. I don't know if it has a separate vent or if it vents through the cap. When it starts losing power, try pull the fuel tank cap off and see if it makes any changes.
   / Losing power when warm. Air filter and fuel filtes changed. What next? #13
Is the engine losing power or the transmission?
From your original post it could be either.
Well transmission I guess. I go out on road,leave in second gear all seems normal. I shift to third it doesn't accelerate. So I decide to turn around . I then have to put in first to take off. Then 2nd again might ge fine. I get in my gate with slight incline. I can't roll ahead in 1st. Have to put in bull 3rd and barely get to my garage without shift8ng it down to second bull.
It's looking like my clutch might be done. 1850hrs. Is this normal wear and tear?
   / Losing power when warm. Air filter and fuel filtes changed. What next? #16
It does sound like your clutch, I’m not familiar with your tractor but maybe you can check runout and adjust?
2023 Kubota Z252KH-54 Zero Turn Mower (A56436)
2023 Kubota...
Honda EM3500S Portable Gasoline Generator (A59228)
Honda EM3500S...
(3) Miscellaneous Water Tanks (A57149)
(3) Miscellaneous...
2011 Peterbilt 365 Altec AC38-127S 5 Section 127ft. 38 Ton Tri-Axle Hydraulic Telescopic Crane Tr... (A56858)
2011 Peterbilt 365...
LOT: (2) Shelves of Komatsu Parts & Filters (CONTENTS ONLY) (A59076)
LOT: (2) Shelves...
UNUSED CFG INDUSTRIAL NT20-CZ EXCAVATOR (A58375)
UNUSED CFG...
