Losing power on my 45TD
   / Losing power on my 45TD #1
Harry Levine
Bush hogging heavy wet grass and losing power. Have upped the rpm to 2400 (2000 is normally fine). Any advice?
   / Losing power on my 45TD #2
Dull blades maybe... Cutting wet grass always takes more HP. Have you checked the blades?
   / Losing power on my 45TD #3
Power loss with FEL? Tiller? Or is it just with rotary cutter?
Bob
   / Losing power on my 45TD #4
Don't know what kind of tractor you're using but it takes 2600 RPM on my rig = 540 PTO RPM.
I can mow at 2000 RPM until the going gets tough, then the RPM gets ramped up.
Thanks all for the advice. Changed my blades and revved up to 2600 rpm. Problem solved.
2012 FREIGHTLINER CASCADIA (A52472)
2012 FREIGHTLINER...
New/Unused 72in Quick Attach Mower King Hydraulic Brush Cutter (A51573)
New/Unused 72in...
2015 Ford Taurus SE Sedan (A51694)
2015 Ford Taurus...
2016 Ford Fusion Sedan (A50324)
2016 Ford Fusion...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
