Losing fluid
/ Losing fluid #1
yanmars
I have a manual transmission tractor. It loses about 2 quarts of hytran fluid in 10 days or so. There are no visible leaks, drips, wet spots that I can see whether it is running, parked or just sitting there. There is nothing attached to the rear remotes. It has a front end loader and PTO mower. Ideas?
/ Losing fluid #2
Check your engine oil level. Many hydraulic pumps are driven off the engine. If they leak the oil can go into your crankcase overfilling it. The cure is to either reseal or replace the pump.
/ Losing fluid
I have checked that and the engine oil is right where it needs to be.
2016 Ford F-550 Service/Mechanic Truck with Crane, VIN # 1FDUF5GTXGEC76689 (A65563)
2016 Ford F-550...
HD Bale Ring w/ Hay Saver (A66408)
HD Bale Ring w/...
Bush Hog 7' 3Pt Mower (A66408)
Bush Hog 7' 3Pt...
20ft Jumper Cables (A65583)
20ft Jumper Cables...
John Deere 772-A Grader (A62679)
John Deere 772-A...
2024 Ranger 1500 Extreme Duty North Star (A62679)
2024 Ranger 1500...
