losing fluid out of the right rear wheel axle
   / losing fluid out of the right rear wheel axle #1
jim means
Olympia,Washington
Yanmar 2000
Losing fluid out of the right rear wheel axle does anyone have more information on the how to's of changing the seal or could it be something else..
   / losing fluid out of the right rear wheel axle #2
Common problem that a lot of us has had to replace them. Including me. Pretty straight forward just pull the hub with a wheel puller and then your be able to get to the Seal. A lot of us also has had to replace the collar. I didn't and had a drip or two after I used it. But that has seemed to have quit after I must to have over filled the Hyd. Fluid a little. Clemsonfor done his collar and don't recall there being any thing difficult about it. Hoye has a parts dia. to look at. But a lot of things are possible how much Hyd. fluid are you losing?
   / losing fluid out of the right rear wheel axle #3
It kind of depends on what kind of fluid you are losing. Those seals don't hold water very well.
Thank-you for the information just bought the tractor and i am still getting to know it i imagine it will take some time glad to have found this site...Again thank-you Jim Means
   / losing fluid out of the right rear wheel axle #5
I did mine. It was an easy job and the parts were less than $20 i think? I did a write up on it and put it here. Let me see if i can dig that post up.
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A50322)
2020 Caterpillar...
2004 Toro Turf Sweeper 4800 (A50322)
2004 Toro Turf...
2002 Wacker RD11A Tandem Smooth Drum Roller (A51691)
2002 Wacker RD11A...
BW RVB3405 20,000lbs 5th Wheel Hitch Base (A50322)
BW RVB3405...
2016 Club Car Carryall 1500 4x4 Utility Cart (A50322)
2016 Club Car...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
