losing fluid out of the right rear wheel axle
   / losing fluid out of the right rear wheel axle #1
jim means
Olympia,Washington
Yanmar 2000
Losing fluid out of the right rear wheel axle does anyone have more information on the how to's of changing the seal or could it be something else..
   / losing fluid out of the right rear wheel axle #2
Common problem that a lot of us has had to replace them. Including me. Pretty straight forward just pull the hub with a wheel puller and then your be able to get to the Seal. A lot of us also has had to replace the collar. I didn't and had a drip or two after I used it. But that has seemed to have quit after I must to have over filled the Hyd. Fluid a little. Clemsonfor done his collar and don't recall there being any thing difficult about it. Hoye has a parts dia. to look at. But a lot of things are possible how much Hyd. fluid are you losing?
   / losing fluid out of the right rear wheel axle #3
It kind of depends on what kind of fluid you are losing. Those seals don't hold water very well.
Thank-you for the information just bought the tractor and i am still getting to know it i imagine it will take some time glad to have found this site...Again thank-you Jim Means
   / losing fluid out of the right rear wheel axle #5
I did mine. It was an easy job and the parts were less than $20 i think? I did a write up on it and put it here. Let me see if i can dig that post up.
2017 Mower Max Flexwing Mower (A51573)
2017 Mower Max...
Kivel Q.A Pallet Forks (A50121)
Kivel Q.A Pallet...
2012 Ford F-350 Mechanics Service Truck (A51692)
2012 Ford F-350...
Probst Metal Cart (A50774)
Probst Metal Cart...
2008 Volkswagen Passat Passenger Car (A51694)
2008 Volkswagen...
2001 Same Argon 70 (A50120)
2001 Same Argon 70...
