Lorer seal in rotary cutter.
   / Lorer seal in rotary cutter. #1
MESSMAKER
Bluegrass,KY
DK4710SE
Lower seal in rotary cutter gearbox
I have always, in the past,went the grease route when a leak started, but I have to remove the stump jumper in order to remove some wire. I think I will just replace the seal while I am at it. Any tips?
   / Lorer seal in rotary cutter. #2
Get your FEL and a chain. Grasp the cutter by the gearbox and lift it and tilt it till the bottom is exposed. Makes the job a lot easier and I guarantee you the gearbox can tolerate that weight and about 10x if need be.
Mark
   / Lorer seal in rotary cutter. #3
If you are taking the jumper and the blades off just remove the gear box. Mine came off with 4bolts and made the removal of the seal alot easier and safer
2022 CATERPILLAR 249D3 SKID STEER (A51242)
2022 CATERPILLAR...
Heavy-Duty 3-Point Bale Spike - Efficient Hay Handling for Tractors (A52128)
Heavy-Duty 3-Point...
2016 Nissan Pathfinder S SUV (A50324)
2016 Nissan...
VERMEER 605F ROUND HAY BALER (A51243)
VERMEER 605F ROUND...
19009 (A48082)
19009 (A48082)
2012 Chevrolet Cruze LS Sedan (A50324)
2012 Chevrolet...
