Lorer seal in rotary cutter.
   / Lorer seal in rotary cutter. #1
MESSMAKER
Veteran Member
Bluegrass,KY
DK4710SE
Lower seal in rotary cutter gearbox
I have always, in the past,went the grease route when a leak started, but I have to remove the stump jumper in order to remove some wire. I think I will just replace the seal while I am at it. Any tips?
   / Lorer seal in rotary cutter. #2
Get your FEL and a chain. Grasp the cutter by the gearbox and lift it and tilt it till the bottom is exposed. Makes the job a lot easier and I guarantee you the gearbox can tolerate that weight and about 10x if need be.
Mark
   / Lorer seal in rotary cutter. #3
If you are taking the jumper and the blades off just remove the gear box. Mine came off with 4bolts and made the removal of the seal alot easier and safer
2013 KOMATSU PC490LC-10 EXCAVATOR (A51242)
2013 KOMATSU...
2015 Silverado 1500 (A50323)
2015 Silverado...
197637 (A50459)
197637 (A50459)
UNUSED AGT SAII100 QUICK ATTACH PALLET FORKS (A51244)
UNUSED AGT SAII100...
2018 JLG SKYTRAK 6036 TELESCOPIC FORKLIFT (A51242)
2018 JLG SKYTRAK...
New Land Honor Skidloader Trailer Mover (A50774)
New Land Honor...
