Loosing Bead on Front R-1 tire/L3830
   / Loosing Bead on Front R-1 tire/L3830 #11
I made the mistake of mowing through some pretty nasty mesquite and wound up with two flats. Tractor Supply has a product called "Green Slime" which, if you follow the directions, will seal punctures and probably the bead problem.
   / Loosing Bead on Front R-1 tire/L3830 #12
Hi Engine66:
I lost the bead on a front last winter; it was on a cold day--I'm 30 miles north of you, so we both know about frigid temps--when I went out to start my L4400, I noticed that one of the front tires was a little low, for no apparent reason. I thought I'd drive it over to the garage to pump the tire up. The first turn I made made the bead pull off, and turned a 3 minute job into an hour job. Hasn't happened since I put air back in---after seating the bead-- so I concluded that the air pressure was a little low in that tire anyway, and the extreme cold weather lowered the pressure even more. Take away advice for me anyway, maybe the ag tires I have can be low on air and not show with a characteristic sidewall bulge. My 8N tires have tubes in them(1951 pre tubeless rims) so beads don't pop off the same, and I'm used to running low pressure for flotation. I think air pressure is the key.
simonmeridew
Simon...Good info..thanks. I will have to keep up on checking the pressure...maybe it did get low like Art says. When I get time, I will get some inner tubes. Take care...
   / Loosing Bead on Front R-1 tire/L3830 #14
This tool has quickly become my best friend. For my front tires, I just lift them up with the bucket and give it a blast and bingo - job done, two minutes.
I saw a local garage use this and knew I had to have one. Even great for Two wheel dolly's with pneumatic tires. One day I watched two of my workers for a half hour try to put a tire back on a dolly using truck straps, etc. so I said that's it - next day I got the cheetah.
Cheetah Bead Seating Tool, Bead Seating Tools | Gemplers
2012 VANGUARD 53FT DRY VAN TRAILER (A52141)
2012 VANGUARD 53FT...
2018 ford explorer (A50324)
2018 ford explorer...
CATERPILLAR 305CR EXCAVATOR (A51242)
CATERPILLAR 305CR...
NEW HOLLAND L180 SOLID TIRE SKID STEER (A51242)
NEW HOLLAND L180...
Woods 7200 3 pt Finish Mower (A50514)
Woods 7200 3 pt...
2014 Jeep Cherokee Latitude SUV (A50324)
2014 Jeep Cherokee...
