Loose gear box on bush hog
   / Loose gear box on bush hog #1
TVZ
MF 1726E
I was running my old KingKutter bush hog through some fairly heavy brush when it started sounding more rattly. Upon looking I saw that all four of the bolts that hold the gear box onto the top of the deck were loose!
I guess I need to get the stump jumper out of the way so I can hold the nuts down there so I can tighten the bolts. But my question is, how could this have happened? How did all four bolts work their way loose? Is there an underlying problem that caused this?
   / Loose gear box on bush hog #2
Ever heard the phrase S*** happens.... Check blades and stump jumper for excessive out of balance..... Suggest lock washers, nylock nuts or Loctite threadlocker when putting it back together.... Also inspect area around where gearbox bolts down for cracks and or metal fatigue....
   / Loose gear box on bush hog #3
As Wrangler said, crap happens. The bolts and nut are probably toast now. Get new gr.8 bolts, locknuts and gr.8 flats. IMHO lockwashers aren't worth crap, they break, add no load spreading to the clamping surface and only come into play when they're already loose. Check the holes and I bet you're going to find them wallowed out so be prepared for either a couple larger size gr.8 flats or some welding.
   / Loose gear box on bush hog #4
No big deal. I had a 72” Land Pride that loosened up. I replaced them with fine thread hardware and locknuts.
   / Loose gear box on bush hog #5
I agree with most advice already given here. If it was mine, I check what grade of bolts the OM used and replace them with the same, or higher. And replace all fastener components like washers, lock nuts, etc etc.
   / Loose gear box on bush hog #6
Joint movement from under tightened bolts. Replace w/Gr8 bolts and Gr8 washers. Tighten to FULL bolt spec. -- Depending on size, probably 200ft-lb or more.
   / Loose gear box on bush hog #7
As Wrangler said, crap happens. The bolts and nut are probably toast now. Get new gr.8 bolts, locknuts and gr.8 flats. IMHO lockwashers aren't worth crap, they break, add no load spreading to the clamping surface and only come into play when they're already loose. [[[Check the holes]]] and I bet you're going to find them wallowed out so be prepared for either a couple larger size gr.8 flats or some welding.
If no cracks yet you can probably get away with adequate clamping to "freeze" the joint. -- The good bolts and washers, TIGHT, will do that.
   / Loose gear box on bush hog #8
If you don't trust the lock washers or lock nuts by them
selves then use both along with some locklite
willy
   / Loose gear box on bush hog #9
Same thing happened on my King Cutter. The lock washers broke and left the gap.
Pulled the stump jumper and replaced with grade 8 bolts and lock nuts.
   / Loose gear box on bush hog #10
I figure it's just part of owning equipment and using it. When it happened to me, I replaced the bolts and nuts with brand new. Some of the threads had worn away and I wanted brand new locking nuts with the plastic on them. I also used red Loctite on the threads.
You don't have to remove the stump jumper, but somebody is going to have to reach in there with a wrench to hold that end of the bolt, while somebody else is at the other end.
You never want to remove the stump jumper if you REALLY DON'T HAVE TOO!!!! It's a really painful thing to do, they are stuck on the gear shaft, and it's never an easy thing to get it off of there.
2019 Caterpillar 299D2 High Flow Compact Track Loader Skid Steer (A51691)
2019 Caterpillar...
2016 Chevrolet Impala Limited Sedan (A51694)
2016 Chevrolet...
2013 John Deere 35D Mini Excavator (A52377)
2013 John Deere...
KMC 5610 (A53084)
KMC 5610 (A53084)
2022 John Deere 8R 310 MFWD Tractor (A53342)
2022 John Deere 8R...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
