Loose draft control cylinder bolts?
/ Loose draft control cylinder bolts? #1
Russcript
Kioti DK50 hst
Hey all, I was doing a little mowing and plowing with my DK50 and the draft control seemed to be a little jerky, when I checked it out I noticed that the 2 nuts at the draft cylinders were loose enough that the top link bracket can separate a hair from the cylinder and seems to be a bit loose. The problem is, the bolts spin freely and without knowing if they are supposed to be tight, I don’t know of this is normal or not. I’m thinking of stopping by a dealership and checking out a new one.
/ Loose draft control cylinder bolts? #2
Those bolts just put some preload on the spring. Basically, you hold it with the flat head screw driver and tighten the nut with a wrench till it's just snug without any play.
Maybe this picture helps you understand a little bit better what's going on:
Thanks, I figured it was something like that but I didn’t want to screw something up without knowing what the normal tension was, I’ll try to tighten them a bit before I go back to work
2003 MAC 45' WALKING BOTTOM TRAILER (A60430)
2003 MAC 45'...
2025 Kivel Fork and Frame Mini Skid Steer Attachment (A59228)
2025 Kivel Fork...
UNUSED FUTURE REMOTE CONTROLLED TOY (A60430)
UNUSED FUTURE...
2013 Ford F-150 Crew Cab Pickup Truck (A59230)
2013 Ford F-150...
2012 Ford F-250 Pickup Truck (A59230)
2012 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
