Loose cylider sleeve?
   / Loose cylider sleeve? #1
Shrpshotr45
Jinma 284
Lost head gasket on my jinma 284 (y385).
Took down top end to replace, and the sleeve on #2 cylinder can be rotated in the block by hand.
Anyone encountered this?
   / Loose cylider sleeve? #2
Is it still holding coolant? The head should lock it in place, i believe it is sealed at the bottom with a large oring and sealed by the head gasket at the top... if the oring was going at the bottom it might move freely...
No water in oil. Pulled head because exhaust was pressurizing radiator.
   / Loose cylider sleeve? #4
A wet sleeve with no "O" rings, it is normal and could indicate there is not out of round when it make a full turn.
If it turn easily with the "O" rings in the bottom, they need to be replaced.
As for dry sleeves, they should have at least some close fit or even being put in place with dry ice help.
As what I have seen in most cases.
Jacques
Fyi....head gasket thickness matters. Re adjust valves after replacememt.
   / Loose cylider sleeve? #7
Those engines was build that way.
I had a 495 ....4 silinder ....95 bore.
Mine leaked thru the block down on the outside of sleeve no 2 and I had to replace my block.
Those sleeves is called slidefitt in the block and not pressfitt.
2012 International 4300 Vacuum Excavation 7.6L Diesel Truck w/Vanair Vacuum (A51692)
2012 International...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
2018 JLG 3246ES 32ft Electric Scissor Lift (A50322)
2018 JLG 3246ES...
MODERN AG PREDATOR 15 15' BATWING MOWER (A51406)
MODERN AG PREDATOR...
1266 (A50490)
1266 (A50490)
Power Liner 4000 Paint Striper  (A52384)
Power Liner 4000...
