Loose Bolts On MMM
   / Loose Bolts On MMM #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
Has anyone ever had problems with the bolts that hold the gearbox on the MMM coming loose. I had 3 loose bolts where the gearbox is bracketed. I thought about locktight, but a friend of mine said the gearbox is aluminum, and the treads would be damaged if I needed to take the bolts out. I put lockwashers on them now. Anyone else correct this at all? Thanks Kent
   / Loose Bolts On MMM #2
The lockwashers ought to hold it. If they don't that means you probably have a thread problem. I would then use the Loctite. If the loctite doesn't work it's time for helicoils.
Thanks bgott, I'll be keeping a close on eye it for a bit. I don't want the gearbox coming loose. I bet that would make a mess. Thanks again Kent
   / Loose Bolts On MMM #4
It should have had lock washers from the factory. Do they ship those mowers assembled or are they dealer assembled?
Yep, I agree. I'm not sure about the assembling part. I bought my tractor used. Thanks for the reply.
2008 VOLVO VHD64B CRANE TRUCK (A52141)
2008 VOLVO VHD64B...
2018 GMC Savana (A50120)
2018 GMC Savana...
John Deere 6125M (A50120)
John Deere 6125M...
2018 Bobcat T590 (A50120)
2018 Bobcat T590...
1989 Freightliner Cabover FLA086 (A52748)
1989 Freightliner...
2010 Freightliner Business Class M2 Cab and Chassis (A47384)
2010 Freightliner...
