Loose Bolts On MMM
   / Loose Bolts On MMM #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
Has anyone ever had problems with the bolts that hold the gearbox on the MMM coming loose. I had 3 loose bolts where the gearbox is bracketed. I thought about locktight, but a friend of mine said the gearbox is aluminum, and the treads would be damaged if I needed to take the bolts out. I put lockwashers on them now. Anyone else correct this at all? Thanks Kent
   / Loose Bolts On MMM #2
The lockwashers ought to hold it. If they don't that means you probably have a thread problem. I would then use the Loctite. If the loctite doesn't work it's time for helicoils.
Thanks bgott, I'll be keeping a close on eye it for a bit. I don't want the gearbox coming loose. I bet that would make a mess. Thanks again Kent
   / Loose Bolts On MMM #4
It should have had lock washers from the factory. Do they ship those mowers assembled or are they dealer assembled?
Yep, I agree. I'm not sure about the assembling part. I bought my tractor used. Thanks for the reply.
LOT: (6) Ratcheting Chain Binders (A59076)
LOT: (6)...
2015 Chevrolet Traverse LS SUV (A56859)
2015 Chevrolet...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
NEW Wolverine 72in Skid Steer Tiller (A59000)
NEW Wolverine 72in...
2002 International 9200i Truck (A56435)
2002 International...
1999 International 9200 Day Cab Truck, VIN # 2HSFMAHR0XC036739 (A57453)
1999 International...
