Loose Bolts On MMM
   / Loose Bolts On MMM #1
Steelfan
Platinum Member
Central PA
New Holland TC21D
Has anyone ever had problems with the bolts that hold the gearbox on the MMM coming loose. I had 3 loose bolts where the gearbox is bracketed. I thought about locktight, but a friend of mine said the gearbox is aluminum, and the treads would be damaged if I needed to take the bolts out. I put lockwashers on them now. Anyone else correct this at all? Thanks Kent
   / Loose Bolts On MMM #2
The lockwashers ought to hold it. If they don't that means you probably have a thread problem. I would then use the Loctite. If the loctite doesn't work it's time for helicoils.
Thanks bgott, I'll be keeping a close on eye it for a bit. I don't want the gearbox coming loose. I bet that would make a mess. Thanks again Kent
   / Loose Bolts On MMM #4
It should have had lock washers from the factory. Do they ship those mowers assembled or are they dealer assembled?
Yep, I agree. I'm not sure about the assembling part. I bought my tractor used. Thanks for the reply.
2006 Audi A6 Sedan (A50324)
2006 Audi A6 Sedan...
2009 Freightliner M2 106 MedTec Ambulance (A51692)
2009 Freightliner...
Memo 98 Loader with Brackets (A50514)
Memo 98 Loader...
Woods 3180 Batwing Mower (A50514)
Woods 3180 Batwing...
2022 NORSTAR IRON BULL 36FT GOOSENECK TRAILER (A52141)
2022 NORSTAR IRON...
10' Unused Feed Bunk (A50515)
10' Unused Feed...
