Loose bolts on 3215
/ Loose bolts on 3215 #1
MrChris
Georgia
Mahindra 3215HST
I was checking over my 3215 today and I noticed there was a slight space on the bottom of where the front axle bolts to the bevel gear on the right side. There are six bolts with 14mm heads and lockwashers. When I got my wrench I was suprised to find them all in need of tightening. Especially the bottom two. When I checked the left side they were all tight. I only have 120 hrs on the tractor so just wanted to let the 15 series guys know to check your bolts. (sound like Mario Andretti---"check your tires") I'm also curious if I should reomove the bolts and apply some thread compound and if so what color or strength? Also, couldn't find a specific torq figure for these? You rarely see lock washers used in autos because of vibration, curious to see them everywhere on tractors.
/ Loose bolts on 3215 #2
Yes, remove the bolts, apply thread lock, and tighten. I looked in my 2615 manual, and saw no specs for front axle bolts. My guess is you need a good bit of torque in that area of the tractor.
/ Loose bolts on 3215 #3
I also checked my factory 2815/3215 service manual for torgue specs for the front MFD assembly and there is no information on much to tighten the bolts. Maybe this explains the use of so many lock washers.
I've checked my bolts at 50 hrs but the ideal of using thread lock compound got by me so it looks like I need to buy a large bottle of thread lock.
/ Loose bolts on 3215 #4
The right side hub is installed in the USA at whatever facility did the final assembly. The left side hub is installed in Japan. They do this so the crate can be narrower and they can get 16 of these in a 40' container. So if you have a right side only issue, it is possible that it did not get tightened properly during final assembly. This sort of issue seldom happens, but people are people and mistakes can happen. Tighten them up, perhaps put a drop of blue locktite on each and you are good to go.
Torque is 29-33 lb ft. There is one bolt that is special as it is a dowel bolt. Same torque. I hope this helps.
Thanks guys. I'm gonna get some thread lock compound tomorrow and retorq the bolts. By the way I errored on my tractor hours. I only have 60 hrs on it.
/ Loose bolts on 3215 #6
Good job keeping an eye on things. Also check the loader bolts, frame bolts and wheel lug bolts occasionally. Just like regularly checking fluids and filters, it is a part of owning a piece of equipment.
/ Loose bolts on 3215 #7
Question for you Dave, did you find this information in the service manual or was it in a service bulletin?
/ Loose bolts on 3215 #8
Neither, we are the distribution center in the west, so I have the Mitsubishi assembly instruction CD for the 15 series models. It is not available to the general public as it has no use other than initial assembly.
/ Loose bolts on 3215 #9
If that CD has torque specs on it, then it would be very useful to us 15 series owners. I believe a complete owners manual should contains the specs for every bolt on the tractor, and I don't believe that is a lot to ask.
/ Loose bolts on 3215 #10
It only has torque specs for the various items installed during final assembly. This is a relatively small list of items. Seat, steering wheel, top of roll bar, right hub, three-point arms, battery, etc.
A service manual on the other hand, should have torque specs. When in doubt, there are torque charts for grade and size of bolts and seldom is any other torque specified. Rods, mains, cylinder heads, flywheel bolts, etc are critical and specific, but in most other places you will find the charts will be right on the money.
/ Loose bolts on 3215 #11
Without the complete listing of torque specs then my service manual is lacking information... is it possibly to get a copy of the CD burned or can you give me a phone number to call and discuss this missing material.
/ Loose bolts on 3215 #12
Sergei, I can't help you with the CD, it is basically useless to you and it is not for external consumption. I have probably given you about the only info that is on the CD that you would lack. I've actually not reviewed the service manual in depth, so I can't comment on how good it is or what may be lacking. As far as a phone number, that would typically be your local dealer. If I have more info that would be helpful I'd be glad to share though. You can email me directly if you would like.
/ Loose bolts on 3215 #13
I don't know about other models, but my ML260 loader manual has a torque specification chart on the second page. It includes bolt diameters from 1/4" to 1&1/2" and Metric from 8 to 30mm. I've also found what is called Special Bolt Torques on the 24/7 Care that includes Cylinder Head, wheels and axles and several others.
/ Loose bolts on 3215 #14
Hi
i just took delivery of an 5500fwd and the dealer made a point of making sure i checked the wheel axel bolts and also the wheel hub tie bolts. He said they had a nasty habit of working loose in the "bed in period". Also he said that Mahindra wouldn"t cover any damage under warranty.
i myself are going to apply loktite to the nuts to make sure.
cheers
/ Loose bolts on 3215 #15
I have watched this thread with interest. I find it interesting that the dealer tells you that the the bolts coming loose would not be covered under warranty. That's a "well duh" to me. Especially if you have a loader, it says right in the manual how often to check bolt touques and what they should be as noted in a previous post. There is no automaker on the planet that will pay warranty even if your front wheel falls off the lug bolts at only 10,000 miles.
/ Loose bolts on 3215 #16
Check your bolts sooner than the manual suggests! Mine on the right side worked loose and one actually broke off in the hub. I cant believe i didnt catch it beforehand.
/ Loose bolts on 3215 #17
Hi do you still have 2615 Manuel I'm having trouble my pto won't work.? Any help apreciated.
