Rotary Cutter loose blades
/ loose blades #1
threebsfarm
bergen n.y.
john deere
changed blades on my lx5 bush hog,tightened nuts down tight but blades are loose and scrape sides of deck. what did i do wrong?
/ loose blades #2
Welcome to TBN.
I can't answer your question, but someone should be along soon that can.
/ loose blades #4
:welcome: check dem blades
/ loose blades #5
I'd go with the other's comments.
The blades being loose would indicate that the new blade's bolt hole is too large and, maybe, the blade is too thin.
The large nuts on a rotary mower can only be tightened so far before they run into a ridge on the bolt. This designed slight looseness allows the blade to rotate out of the way if something is hit. The fit has to be exact.
The blades hitting the sides is another giveaway that the blades are wrong. They should miss the sheet metal by 1" to 2".
My advice: Take the old blades, the new blades, the large nuts and bolts to a tractor dealer and match them all up correctly. Tractor Supply might have what you need.
What brand of "bush hog" are you working on?
Jumper Cables (A64127)
2015 Cat D6T LGP Dozer (A62679)
2015 Cat D6T LGP...
New/Unused Landhonor Quick Attach Pallet Forks (A65583)
New/Unused...
New/Unused Wolverine 72in Tiller (A65583)
New/Unused...
Hickory Lumber (A65640)
Hickory Lumber...
2019 International WorkStar 7300 4x4 Altec AA55 56ft. Insulated Bucket Truck (A60352)
2019 International...
