Loose 3pt lever on L245
   / Loose 3pt lever on L245 #1
RMEADOWS
Lakeland, Fl
MF 1428
My tractor sat for about 3 months (I know, a sin) and when I went to use it, the 3 pt adj lever would not stay in place. If I did not have it against the stop nut, the lever would vibrate and start dropping the implement.
And ideas what would be causing this?
   / Loose 3pt lever on L245 #2
i dont know sorry but mine also drops by itself and i will be watching this post
mine has done it for as long as i have owned it
   / Loose 3pt lever on L245 #3
I have an L2201DT and it's the same as the L245. I think there is a double nut on the shaft that the arm attaches to . Just loosen the outer , tighten the inner and then tighten the outer back up again. Very easy. It has been a while since I did this so it may be slightly different then I described , but it is very easy to fix. I'll look in the book this afternoon and be sure. I'll let you know if it's different then I described.
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2001 HAULMARK ELITE II 8' X 24' CARGO TRAILER (A51247)
2001 HAULMARK...
2024 KMC 7406 LOT NUMBER 11 (A53084)
2024 KMC 7406 LOT...
2022 McConnel TRAXX RC28 43in. Remote Controlled Slope Mower (A51691)
2022 McConnel...
1980 TIGER TA KILL TRAILER (A53843)
1980 TIGER TA KILL...
