LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,172
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Well here is a bit of a different take.
Depending on your ground if you have hills like we do in Eastern NY I would recommend an over 100HP tractor for a round baler.
I would also recommend a silage capable baler as many times it will not be possible to get quality hay cut and cured for dry baling,
while a haylage bale can be done easily. With having the capability of making a silage bale or a dry bale the flexibility of making quality
forage becomes much easier.
Also unless you have more then adequate dry bale storage, a round bale wrapper will be very beneficial.
You will notice that I have mentioned quality forage, for the best quality beef you need quality forage.
Once a brood cow becomes a mature animal she can survive on much lower quality feed and actually raise a calve on such feed.
However if raising feeder beef to use and sell poor quality forage will slow down the growth rate and reduce the quality of the beef.
I can not understand the mentality of raising quality forage, baleing such, then leaving it out in the field to mold and rot, then feeding that garbage to beef animals your are raising.
I do realize that some parts of the country can get by leaving bales outside on the ground in the wet humid Northeast you will have at least 30% spoilage when doing so.
If you are baleing late July or August cut first cutting hay that will not make my definition of quality forage. It will have low protein and low digestibility, it may keep animals alive it will not raise quality beef.
To get back on track yes I'd want over 100HP on hilly ground with a round baler or even a small square if towing a wagon while baling.
I would definitely want 4wd on my loader tractor especially in the winter.
A small tractor can rake or ted hay and run a bale wrapper but that is about it.
For routinely carrying round bales on rough frozen ground in the winter, stacking bales 2 high, handling silage bales, the ability to haul a loaded feed wagon through mud and manure you need size and strength.
