Looking to identify what hose I need to get
   / Looking to identify what hose I need to get #1
Andrewnyc
Allmand brothers 425
Hello, I have an Allmand 425 and need to replace a leaking left side stabilizer hose. it measures 30” from end to end of the bolts with the flair, and has an outer diameter of about 19/32”.
They are 3/4 “ wide bolts, and there sides are 11/16” long. The metal jacket along the ends is 1-3/8” long. Any assistance is appreciated .
thanks,
Andrew
   / Looking to identify what hose I need to get #2
Your going to have to take it off to determine if it’s npt or jic fittings. Just remove it and take it to a hydraulic shop or anywhere that make hydraulic hoses, it looks like standard fittings probably 3/8 jic as a guess.
   / Looking to identify what hose I need to get #3
Agree with setxjefff above - most large truck shops have a full size hydraulics shop that can make you a new hose if you don't have a tractor repair shop near you.
Ok thanks I’ll take it off in a few and post pics because I have to order it
Ok so it appears to me it’s a bi hose - female to female straight crimped jic 37 degree sae 3000 psi I plan on putting the protector over it - the right way this time- the original didn’t hit the right point.
anything else I need to know?
one think if I kook into the fitting in the hose direction where it is crimped, it looks like it’s 1/4 “ I assume that’s normal.
appreciate any input
thanks
Andrew
   / Looking to identify what hose I need to get #6
The two files may help you...
  • high_pressure_quick_release_couplings.pdf
  • thread_guide.pdf
Thanks for the help On the hose
1994 PETERBILT 379 SLEEPER (A50046)
1994 PETERBILT 379...
2021 CATERPILLAR 299D3 SKID STEER (A51242)
2021 CATERPILLAR...
2016 CATERPILLAR 299D2 SKID STEER (A51242)
2016 CATERPILLAR...
Case 721B (A47384)
Case 721B (A47384)
2015 BMW 3 Sedan (A50324)
2015 BMW 3 Sedan...
Land Honor Quick Attach Articulating Boom Brush Cutter (A50514)
Land Honor Quick...
