looking to buy a 3 pt tiller
   / looking to buy a 3 pt tiller
You have the advantage of not needing it right now so just be patient and something will turn up. I use apps like "Search Tempest" to search all of CL when I'm on the hunt for something. Sometimes I find it a few hours away, but if the price is right my time is worth it.
Mine is also a KK and it has held up well. I just use it for my personal garden and to help out a couple of neighbors so it really doesn't get much wear.
Never heard of search tempest, but just tried it and it looks great! found a JD tiller I may go look at, not far away. $600 for a 6' tiller, needing a little work. Would save a grand if it is as he says...
Thank you.
   / looking to buy a 3 pt tiller #13
I'm not sure if KK manufacturers their own or not, but there are some manufacturers you might not normally hear about since they make implements for others. Mine is a Taylor Pittsburgh that is painted blue and has the LS logo.
   / looking to buy a 3 pt tiller #14
I've had a 5' KK behind a 30 HP B Kubota for 17 years now. It's done a LOT of tilling and I couldn't be happier with it. Zero problems. Hard to believe how well it works.
   / looking to buy a 3 pt tiller #15
I run a 4 foot Tar River tiller behind my JD X585 (18 HP PTO I think) and it works well. It is a bit lighter than others of this size though.
The brand seems well built.
   / looking to buy a 3 pt tiller #16
I ordered the Rural King by KK 60” tiller for my Kubota L3901.
I ordered it 10-8-21 free shipping to store, it’s expected deliver date is by 1-28-22. The current price is $350 more than my ordered price (my RK Harvest card has not been charged yet). If you’re buying new, you may want to go ahead and order it in hopes of it arriving by spring.
Mike
   / looking to buy a 3 pt tiller #17
I don't have a lot of experience with tillers but I went with a 66" Sicma / Phoenix Tiller
It has the reverse rotation and did a superb job tilling a new 1/2 acre lawn for me. Seems to be built like a tank.
   / looking to buy a 3 pt tiller #18
Buy big enough to cover and really heavy duty, you won't regret it and just don't buy avocado toast for the next year if you strain the budget
The 30hp may require you to go a bit slower, but it'll handle it.
I found this monster at auction for $1k and I'm just amazed at how quickly my tractor (Branson 3520h - "29hp PTO" claimed) tears up untouched rocky ground, despite my hp likely being on the lower end of the recommended range (or even below it - the tiller is over 80" across and had 9 sets of tines).
   / looking to buy a 3 pt tiller #19
I have the KK 5' tiller and run it behind my 20hp Kubota. Tractor is a little small for it, but it works fine. I originally bought it when I had sand for a yard. I now have rocks, gravel, and clay. It still works on that but really gives my tractor a workout. I use 1st gear and 4wd to till the hard stuff.
   / looking to buy a 3 pt tiller #20
I have a 6' King Kutter tiller I run on my 35HP tractor
2018 ford fusion (A56859)
2018 ford fusion...
2004 Freightliner FL60 Ambulance (A56858)
2004 Freightliner...
4 Cubic Yard Dumpster (A55851)
4 Cubic Yard...
(3) 24"x18' PVC Pipes (A56469)
(3) 24"x18' PVC...
2006 Ford F-650 Crew Cab Aluminum Landscape Dump Truck (A55852)
2006 Ford F-650...
UNUSED RAYTREE RHBC72 - 72" HYD BRUSH CUTTER (A57193)
UNUSED RAYTREE...
