Looking for Welder
/ Looking for Welder #1
jtn
Illinois
New Holland TC45D
I am looking for a welder for some light work on implements and such around my house. I do not forsee having to weld on anything thicker than 1/2", and probably not even that thick. Since this will be a limited use tool for me I would like to avoid spending more than about $600. If possible I would like a machine that would run off a 240v plug and have both MiG and ARC capability.
I have heard good things about Lincoln and Miller machines but am open to any suggestions in terms of make and model.
If nobody knows of a welder in this price range I am open to more expensive suggestions.
Thanks in advance,
JT
/ Looking for Welder #2
I just bought a little Hobart 175 Mig welder that'll weld up to 1/4" in a single pass. It's 240V and retails at $650 at Tractor Supply Company (TSC). I dont' know enough about welding to recommend it or not. It just sounded like it met a couple of your requirements and was in the price range you wanted. Good luck in your search. /w3tcompact/icons/smile.gif
/ Looking for Welder #3
I have a Hobart Handler wire welder. It is rated for up to 1/4" also. I like it very well. You can weld thicker than 1/4" if you preheat your work. I have welded 1/2" plate to a 1 1/2 diameter shaft to make a trailer hitch. Never broke it and still have it.
/ Looking for Welder #4
I don't think you are going to find a combination machine in that price range, but you could probably pick up a Hobart 130 and a Hobart StickMate at TSC for around the price you are talking. The 130 is a 110v wire machine, which you could use for the lighter stuff, and use the StickMate for your heavier stuff.
/ Looking for Welder #5
I am with EdKing . for the price range you stated i don't think your going to find a machine. i would recommend a arc welding machine like a lincoln ac 225 . i have a century but wouldnt recommend one . they change there machines alot. my next will be a lincoln , miller or hobart.
2005 CATERPILLAR TH460B TELESCOPIC FORKLIFT (A65056)
2005 CATERPILLAR...
2021 IDeal RC6MD 6ft. Rotary Brush Cutter Tractor Attachment (A66734)
2021 IDeal RC6MD...
2022 HLA 54in. Hydraulic Root Rake Grapple Attachment (A66734)
2022 HLA 54in...
3 Point Hitch Attachmnet (A66734)
3 Point Hitch...
CAT J600 Teeth (2) (A68134)
CAT J600 Teeth (2)...
FUEL TANK WITH PUMP AND HOSE (A68842)
FUEL TANK WITH...
