Looking for valves for gas 444
   / Looking for valves for gas 444
IH typically listed engine parts separately. Get the engine model from the block (probably hand stamped on a flat machined boss on the right side) and look up parts that way.
I thanks I found valves , figured out the way ngine wax a bc144 . Not very commen and valves where a lot of money. Got the tractor running yesterday and starts right up now
   / Looking for valves for gas 444 #23
Just a quick question . What are you using for hydrolic oil I assume it's all together and where do you fill and where do you check level , I have no owners Manuel and the service one does not say
For hydraulic oil I buy the relatively cheap five gallon pail from Canadian Tire. The filler plug is located behind the seat on the right side of the tractor. For decades I was bothered by a persistent hydraulic oil leak from around the suction strainer (located near the operator's right shin) so I finally decided the leak was caused by the hydraulic reservoir becoming pressurized when hot. There may well be a vent to this reservoir somewhere but I can't find it and if there is one on mine it must be plugged. The suction strainer has an o-ring on it but is simply pushed into the casing so it doesn't seal well. The o-ring is an odd ball size and I couldn't find one in my area when I decided to fix this problem a few years ago so I replaced the filler plug with a venting pipe. I'll attach a photo below. This cured the leaking problem although I see that the o-ring is now available from Messick's for a whopping U.S. $8.16! New Holland / Case IH: O-RING, Part # 74348R1
The level of the hydraulic oil should be just at the bottom of the filler neck with all your hydraulic cylinders completely retracted. Put the loader over a ditch or something similar to achieve this. The hydraulic system drain plug is located about a foot below the filler plug. I hope this helps.
   / Looking for valves for gas 444 #24
The arrow in the photo points to the drain plug. Note the cloth "filter" on the end of my vent pipe.
Is the tranny a different compartment and different grade oil
   / Looking for valves for gas 444 #26
Yes the tranny is a different reservoir then the hydraulic on these tractors.
   / Looking for valves for gas 444 #27
thanks for the reply, No the reservoir is not overfilled according to the manufacturer. If anything it is a little low when I look in from the top.
Mini John Deere Truck (A55853)
Mini John Deere...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2022 Schulte 2500 Giant Rock Picker (A55314)
2022 Schulte 2500...
1996 JCB 506B Telehandler (A57024)
1996 JCB 506B...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
