Looking for valves for gas 444
   / Looking for valves for gas 444
Received the valve wed from agkits.com and it's the right valve . They drop ship from a company called reliance power . You need to b a dealer to see parts they sell or to buy from them . With any luck it will be togeather next weekend
   / Looking for valves for gas 444 #12
Good deal..!!
   / Looking for valves for gas 444 #13
For your future.... here's an IH salvage yard in Bourbon, IN that I've dealt with before. Good folks. Very knowledgeable....
Bates Home Page
Thanks for all the help guys I put the head on and got it purring like a kitten . Hydrolics and 3 point hitch work fine and I drove it around the block . Clutch could be adjusted and the brakes need work . I'm ready to start on all the small stuff now I know t runs good
   / Looking for valves for gas 444 #15
Hi Terry,
I'm glad to hear you got it running. I'm curious why you needed new valves anyway. In your photo that tractor looks very well kept and I think you got a good deal on it. Do you know you may have a two stage clutch - half way down for changing gears and all the way down for starting and to engage/disengage the PTO? Here's a photo of my Canadian 444/U.S. 354.
That's the same tractor . Fellow in the shop told me the valve stems where worn on a tapper . The 4 valves cost me $340 then $294 for all gaskets and $280 to surface grind head and rebuild it then a boy $120 for all new ignition parts . I'm up about $3500 total now
   / Looking for valves for gas 444 #17
For quite a few years I had recurring ignition problems with my tractor until I twigged that all the distributor and coil terminals should be liberally coated with di-electric grease. That made it very reliable (knock on wood!).
I'll do that . I hope to replace all the small wires going to could and cap then I'll do the same . I want to make sure all gauges work first of all and the tac
Just a quick question . What are you using for hydrolic oil I assume it's all together and where do you fill and where do you check level , I have no owners Manuel and the service one does not say
   / Looking for valves for gas 444 #20
IH typically listed engine parts separately. Get the engine model from the block (probably hand stamped on a flat machined boss on the right side) and look up parts that way.
2023 Bobcat T66 Two Speed Compact Track Loader Skid Steer (A55851)
2023 Bobcat T66...
2019 Chevrolet Tahoe SUV (A55853)
2019 Chevrolet...
2013 Ford Fusion SE Sedan (A55853)
2013 Ford Fusion...
2019 Chevrolet Cruze Sedan (A53424)
2019 Chevrolet...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
Informational Lot - Financing (A57024)
Informational Lot...
